Old 08-06-2016, 10:00 AM   #1
Bill and Gail's Avatar
Safe-T-Plus or RSSC?
I am getting ready to replace the steering stabilizer on my 2016 3010DS. I am trying to decide if I should use the Safe-T-Plus or the Roadmaster RSSC. So far The only differences I can find are:
1. the placement of the return to center springs
2. Safe-T- Plus has a limited lifetime warranty
Which do you use or suggest?
Bill and Gail is offline   Reply With Quote
Old 08-06-2016, 10:30 AM   #2
geeman53's Avatar
We have the Roadmaster and we are happy with our choice. The roadmaster and four Bilstein shocks make for a well controlled MH !
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 08-10-2016, 10:17 PM   #3
Thanks for the info.
Old 08-11-2016, 06:44 AM   #4
I have the safe t plus and am happy with it. Wasn't hard to install. I also put Bilstein shocks on and a Henderson rear trac bar. With these 3 upgrades it makes a world of difference! I have a 2015 3010.
Brian217 is offline   Reply With Quote
Old 08-11-2016, 09:25 AM   #5
Thanks Brian217
Old 08-11-2016, 10:09 AM   #6
Land of the Midnightsun
jjSpeedwagon's Avatar
We have a 2016 coachmen concord 300 DS and I installed the safe t plus on ours and it was a night and day difference. The concord originally didn't handle bad but at times pulling a Jeep Wrangler I'd get this floating or drifting feeling in the front end. When big truck would pass me wouldn't blow me off road but I knew he was there. After the install of the safe t plus. The front end is tight and firm and when trucks pass or hard side wind there is very little steering correction. I now have about 1000 mile on it now and was a worth while investment. Like Brian said it is an easy install I also like the dual spring of the safe t plus instead of taking one spring and compressing and stretching it
John & Janice
2016 Coachmen Concord 300DS
2010 Jeep JK 2.5 inch lift 33' tires
Elite Ready Brutte tow bar & Blue Ox base plate
Never mistake Knowledge for Wisdom. One helps you make a living the other help you make a LIFE.
jjSpeedwagon is offline   Reply With Quote
Old 08-11-2016, 10:26 AM   #7
Thanks jjSpeedwagon
