Old 04-02-2015, 06:12 PM   #1
Wig
sanitize 2015 Sunseeker 3010DS
I followed the directions in the owners manual but could not find the fresh water valve under the bed of the motorhome. Opened valve of grey water tank to see if all water would flow out that way but was not successful. Called service center at purchase location but their suggestions didn't work. Could someone describe the valve to the fresh water tank and where it is located? I am so frustrated!!!!!!!!!!! Any help would be greatly appreciated.
Wig is offline   Reply With Quote
Old 04-02-2015, 07:00 PM   #2
Passenger side, next to last compartment going toward the rear of the coach. Inside the compartment there will be a small black door access panel. Behind the panel is the water filter and the fresh water tank drain. A valve on a blue hose.
Trail blazer is offline   Reply With Quote
Old 08-24-2015, 09:08 PM   #3
MSGCOONS's Avatar
Send a message via Yahoo to MSGCOONS
There's a fresh water tank, grey water, black water tank. The fresh water tank drain valve is in with water filter compartment. The fresh water tank valve is not the same as the grey tank.
MSGCOONS is offline   Reply With Quote
Old 08-25-2015, 09:10 AM   #4
I also having a 2015 3010DS
The valve is located inside the storage compartment under the fresh water fill (which is located under the bedroom slide out at the Passenger side).
Inside the storage compartment you will find the small black door, in it you can find all you need, valve, water filter, and water pump.
karcarkar is offline   Reply With Quote
sunseeker
