Sanitizing Fresh Water Tank Question
I'm attempting to sanitize the fresh water tank. After preparing the proper amount of solution, I begin pouring it in the tank using a tube attached to a funnel. Problem is the solution begins to come out the opening immediately. Almost nothing is going in the tank. The tank fills just fine using a hose attached to a spigot. Pressure the obvious answer there. What's the trick to getting the solution in the tank with out losing 90% of it down the side of the RV.
