Old 02-23-2015, 03:23 PM   #1
Boso's Avatar
Satellite cable
What would be the best way to get a satellite cable into the bedroom for tv or the living room on a 2015 3050s I'm not interested in running thru window
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 02-23-2015, 03:53 PM   #2
You can run a loop in the system to utilize the existing cable-in jack on the wall. Takes a moment to switch a small cable jumper to switch it from over cab tv to the bedroom, but it is the easiest modification to allow use of the satellite and cable through the same external jack. There's several recent posts, a tutorial, and wiring schematics on how to modify the existing connection. Takes about 10 minutes.
Only problem i still have is where to put the dish receiver when in use with the front tv. Hate to have it sitting and taking up space on the over cab bed.
mattnlisa is offline   Reply With Quote
Old 02-23-2015, 04:06 PM   #3
Old Timer
Not familiar with the setup on your unit, but my solution on my last couple of fifth wheels -- my DirecTV receiver connects to the main TV in LR -- is to connect an RF converter to the receiver and backfeed the signal up the antenna feed to the bedroom TV using a bidirectional splitter to connect into the antenna line.This because the DirecTV HD receivers do not have an RF out jack anymore. Not as good picture quality that way, but I don't want to have a second receiver for the second TV. BTW if you use a RF remote for the receiver you can tune from the bedroom or wherever...
If you need more specifics on how to do the connections, give me a holler back.
kentnjudy is offline   Reply With Quote
Old 02-23-2015, 04:06 PM   #4
Boso's Avatar
That's great and what I'm looking for I should be able to find it Thanks
Old 02-23-2015, 06:44 PM   #5
Boso's Avatar
I am completely ignorant on this beyond running the satellite cable directly to the reciever and from the reciever to tv I'm still looking replies Hopeing to understand going to use tailgater
Old 02-23-2015, 07:13 PM   #6
Originally Posted by Boso View Post
I am completely ignorant on this beyond running the satellite cable directly to the reciever and from the reciever to tv I'm still looking replies Hopeing to understand going to use tailgater.
I just set the Tailgater with the handle pointing North, connect cable to TG and then cable to the "Satellite" connection on the side of the camper and then go program the Dish to the state/town we are in. It is a trouble free system and pretty simple to use, otherwise I couldn't do it. We love ours after using it for 3 months in FL.
Old 02-23-2015, 09:38 PM   #7
Boso's Avatar
Does anyone know where to look for Bclemens schematic posted on satellite cable antenna satellite
Old 02-23-2015, 09:58 PM   #8
Boso's Avatar
Thanks guys got the schematic downloaded I should be able to get it now
Old 02-24-2015, 08:26 AM   #9
GM
bclemens's Avatar
here, just in case.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 02-24-2015, 09:26 PM   #10
osgood's Avatar
Sat TV is not difficult... Follow the wiring path... As long as you have it into the system in the front TV that receives antenna reception, there has to to be 2 legs of reception. More than likely the rear TV will need to be on channel 3 or 4 depending on the Sat receiver channel switch setting. In a 2015 model I would be amazed if FR has not made a direct path for sat TV input. Not many places offer cable tv hookup anymore. If not... Shame Shame.
osgood is offline   Reply With Quote
satellite
