Old 12-14-2012, 01:27 PM   #1
Commercial Member
Satellite Systems
Winegard did confirm that the satellite signal does not play well with their electronics (even with power off). This is what they said today...
"a simple solution for the customer that wants to connect a satellite to the park cable, would be to disconnect the park cable from the back side of the antenna power supply (booster), connect that cable to the satellite receiver. Then run another cable from the receiver to the same spot on the power supply. They will then have to turn the power supply off to let the satellite signal go through."
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 12-14-2012, 08:14 PM   #2
Plain Old Member
Thanks bclemens for this clarification. I had inquired about this in the forester section. Sounds pretty much like what I had mentioned over there in regards to bypassing the booster on sat signal in. Wish in the future they would be wired with a separate satellite in jack since sat TV in Motorhomes has become the norm.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
