Old 03-05-2018, 10:24 PM   #1
Sunseeker
Schraeder Valves
I have a 2014 Sunseeker 3170D that has a schraeder valve in each rear compartment. What are these for? Air shocks? Bought this in Dec. and of course it came with no manuals so everything is by trial and error. I just got a Tow Master Dolly and the manual for it calls for 18-24" +/- hitch ball height. As the coach sits right now, I have 13". Can I adjust that height with air if in fact these are air shocks? Thanks for any input...
wingunder is offline   Reply With Quote
Old 03-05-2018, 10:31 PM   #2
moxnix92's Avatar
They should be for the air bags. Adjust them to the height you like up to 90-100 psi max
moxnix92 is offline   Reply With Quote
Old 03-05-2018, 10:52 PM   #3
Duckogram's Avatar
You most likely have Firestone Ride Rite Air Bags. They are not air shocks and don’t operate the same way. Most folks have them set between 50 and 90 psi for a stability and level ride. I doubt you can get the height you need with them.
My suggestion is to use the bags to level under normal load and measure for the offset hitch receiver you need for your dolly. Just my .02˘
ILB ( | )
Old 03-06-2018, 06:59 AM   #4
This is correct.
Just to add, you must always have 5-10 PSI in bags to prevent them from getting pinched and damaged. You may gain 1-2” of height with them fully inflated. They do tend to need topped off frequently. I run mine at 75 PSI.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is online now   Reply With Quote
Old 03-06-2018, 01:28 PM   #5
Sunseeker
Schroeder Valves
Thanks for the replies all. Good info to know. Never dealt with bags before, just air shocks on an old El Camino. But I figured I might need an offset hitch. Guess I can get one at my local RV supplier or on line. Thanks again!
Old 03-06-2018, 03:14 PM   #6
fliper74's Avatar
Originally Posted by Steve-W View Post
This is correct.
X2
fliper74 is offline   Reply With Quote
Old 03-06-2018, 04:02 PM   #7
Empty Nesters
KenandCarol's Avatar
Or your local hardware store; Lowes, Home Depot, ACE, Harbor Freight.
Or auto parts store...they all have them.
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
valve
