Old 12-22-2013, 03:20 PM   #1
Storey's Avatar
Schwintek bedroom slide does nothing on 3170
Anyone know where this 30 amp fuse is on the 3170 ? The slide is in and does nothing. No noise , doesn't try to start. I have reset the controller multiple times, nothing
Thanks Steve
Storey is offline   Reply With Quote
Old 12-23-2013, 09:58 AM   #2
Love My Sunseeker
DXSMac's Avatar
May have to go get it repaired. Earlier this year my slide worked but only went out two inches. Turns out I broke some time of "pin."
How do you "reset the controller" as you say?
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 12-23-2013, 10:18 AM   #3
The controller is in the outside storage compartment under the slide - mounted on the ceiling of the compartment.
Storey - Check for the LED flashes. Quite easy to diagnose. The circuit is protected by an automatic circuit breaker - I believe. Make sure the batteries are fully charged and the battery switch is closed. Seems like an obvious point but when you have 12 volts being provided by the converter, it is easy to overlook that someone opened the battery switch.
Bobby
bgilly is offline   Reply With Quote
Old 12-23-2013, 04:07 PM   #4
Storey's Avatar
Yes in the storage compartment under the slide it self
Old 12-23-2013, 04:10 PM   #5
Storey's Avatar
Have had it not come in several times before. Maybe the motor is toast or a wiring problem. It has been doing this on and off for six months and I just can't get the problem isolated
Old 12-23-2013, 06:36 PM   #6
There are 2 motors on the Schwintek so not likely both are totaled. The control box will tell you what's going on based on the led flashes.
Old 12-23-2013, 06:48 PM   #7
Storey's Avatar
It says is the front motor. I just don't know if it the wiring or the motor.
Old 12-23-2013, 06:51 PM   #8
Probably the wiring. I noticed mine exposed near the interior fascia under the bunk. I removed the fascia and secured the cable a little better. Unfortunately I didn't take pictures.
3170, bed, bedroom slide, roo, slide
