Old 04-23-2016, 12:15 PM   #11
2015 Sunseeker 2300
the screen is well over the side of the furnace vent if it gets hot enough to melt the tubing then I would think it would melt the side of the RV plus doesn't vacuum hose get hot under a hood and not melt?? Humm I thought I was doing something good...
Gingsnap is offline   Reply With Quote
Old 04-23-2016, 12:17 PM   #12
Left Coast
Never had a scratch in over 2 years.....for the fridge and A/C, use alum. screening from HD or Lowe's, cut with scissors, and used alum. heat duct tape...
Sent from my XT1585 using Tapatalk
Old 04-23-2016, 12:23 PM   #13
dan-nickie's Avatar
Looks Good. Great job man!
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 04-23-2016, 12:32 PM   #14
Our service mechanics insist that we only use these screens when not using the appliance otherwise, they will limit their air intake and can actually cause serious problems. Check the manufacturer, they are the ones who told our techs.
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 04-23-2016, 12:41 PM   #15
I also have heard that certain types of screen material may inhibit flow of air and have an adverse effect on operation, but I have never actually seen this in writing. It seems feasible - otherwise the factory would use a smaller gauge screen material.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 04-23-2016, 12:46 PM   #16
If you have square bumper caps cover those holes also,wasps/bees/snakes! Youroo!!
Old 04-23-2016, 01:27 PM   #17
I use no pest strips cut in small pieces and just set them inside the door of water heater, furnace or anywhere wasps or bugs get. They work great.
craig111 is offline   Reply With Quote
Old 04-23-2016, 02:42 PM   #18
rcla2014's Avatar
Originally Posted by Gingsnap View Post
I added screens to the water heater and furnace but did not want the edges scratching the side of the rv..so I added vacuum hose tubing to the edge...I think I did a pretty good job!
Here's a link to the ones you can buy on Amazon. You can get the at the dealer too. They have them for the water heater too. Do not need to put rubber on for protection.
https://www.amazon.com/dp/B00192JFBI/ref=cm_sw_r_sms_awd_d48gxbCJNJJGJ
rcla2014 is offline   Reply With Quote
Old 04-23-2016, 03:04 PM   #19
Found some stainless screen and mounted it under the intake/exhaust plate.
Found out NC mud daubers can get into the "add on" screens.
Name:	Furnace screen.JPG
Old 04-23-2016, 03:31 PM   #20
It may seem the screen is a little too large for your setup. I purchased a round set of screens that fit over each vent without going over the edge. It makes a tight seal against the Mud Dauber from entering. They are attracted to the smell of LPG. They are a large wasp and can sting if bothered. Not good to have aboard. The nest can also be blown up using a M-80.
Tropiccafe is offline   Reply With Quote
furnace, heater, water, water heater
