Old 06-11-2016, 07:53 PM   #1
Sealant Around Tailights
Want to re-seal the taillights on my 3010, do not want to use silicone. Any recommendations?
rekwiat is offline   Reply With Quote
Old 06-11-2016, 10:10 PM   #2
I just used Lexel for redoing a lot of spots around my 3010. Works really well, but Lowe's only had it in clear. I don't know if it comes in white.
Brian217 is offline   Reply With Quote
Old 06-12-2016, 06:47 AM   #3
Chief tinkerer
Gidyupgo's Avatar
Ok, I'll bite.... why not silicone? Thats my "go to" for this type of leak when the seal isn't sealing, but I am open to a better product if it's out there.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 06-12-2016, 11:01 PM   #4
Total Loss's Avatar
I used silicon.
Just used the solvent based stuff.
Difficult to work with but lasts long- cleans up with mineral spirits.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 06-14-2016, 08:53 PM   #5
MH Noob
I have been using Sikaflex 505 UV. I have been thrilled with it. I use it on every seam that shows any signs of fading. It has built in UV protection so it should last a long time. However, for added security on the inside of the tail lights - I used butyl tape around the perimeter and then sealed the outside edges with 505.
Slimjc is offline   Reply With Quote
Old 06-14-2016, 09:35 PM   #6
Chief tinkerer
Gidyupgo's Avatar
Very thorough Slim. Sounds like you have had some experience with hard to seal tail lights. Do you do the same on the front clearance lights?
Gary
Old 06-14-2016, 10:13 PM   #7
MH Noob
I am trying to figure out a solution for the clearance lights - I ordered some sealed dragon eyes that I am going to give a shout this weekend - I can update once finished - so far I am liking the idea since they are sealed LED.
Old 06-14-2016, 10:35 PM   #8
member
hey,
i have a 2017 camper. the tail lights were poorly installed, and need sealing.
my dealer warned about doing repairs myself, for concern of voiding warranty.
the last time i had my BRAND NEW camper in for warranty work, i got charged full price for the repair, after the work was done.
i'm in a quandary here.
2017 T19QBHW
robhagen is offline   Reply With Quote
Old 06-15-2016, 09:25 AM   #9
Total Loss's Avatar
Originally Posted by robhagen View Post
hey,
Sealing a poorly sealed contact point yourself should not void ANY warranty. Tell them you actually helped them by being proactive in mitigating what could be more extensive moisture damage.
Unless somehow you damaged a component- then it would not be warranty...it would be negligence or an accident.
If some dealer told me that I would laugh in his face, and go elsewhere or fix it myself. Contact the manufacturer and explain the issues with the dealer if they give you static on a warranty repair.
My dealer ordered me a taillamp and shipped it to me to install myself under warranty just this year.
W. Churchill
Old 06-15-2016, 09:51 AM   #10
jeff64's Avatar
I'm a firm believer in dielectric grease on most types of exposed electrical connections, grounds and bulbs
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
light
