Old 01-28-2018, 05:43 PM   #1
Seat swivel
Was at a show and noticed the forester had swivel seats. I have a 2014 3010DS and would like to swivel the pass seat. Where can I get the base?
Mike3393 is offline   Reply With Quote
Old 01-28-2018, 06:06 PM   #2
Try typing "Swivel seats" into the search box...
Phil
PhilG is offline   Reply With Quote
Old 01-29-2018, 09:45 AM   #3
RedLdr1's Avatar
Google "Ford E450 swivel seat" and several vendor will show up when you click on "Shopping".
If you have the power drivers seat option you cannot add a swivel base to it...
Wayne and Christine
2020 Sunseeker MBS 2400Q On Order
RedLdr1 is offline   Reply With Quote
Old 01-29-2018, 07:09 PM   #4
We have some aftermarket ones (2016 E450) The pass side turns roughly 160deg. Not bad, I like sitting there. The driver's side turns about 90 degrees. I like sitting there too, with a laptop.
Dp26 is offline   Reply With Quote
Old 01-29-2018, 08:30 PM   #5
Dp26 where did you get your aftermarkets, only want one for passenger side. Model #etc would be helpful. Thanks!
Old 01-29-2018, 09:42 PM   #6
Ford Van Seat Bases,driver,passenger seat bases
In my case, the dog house is what limits the turning. I believe there are some which slide and swivel, at a higher cost, from a different source.
Old 01-29-2018, 10:20 PM   #7
The bases the factory uses are manufactured by Atwood. Not sure if they are avaliable aftermarket or only through FR.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 01-30-2018, 11:49 AM   #8
When installing the swivels how much does it raise the seat up ?
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 01-30-2018, 11:56 AM   #9
For me, maybe lower less than an inch. It did not cause any problems with the house floor height and clearance. In my case, I added washers to the front to give more support to thighs (pass), and washers to both front and back, so raise me up as high as could fit without changing bolts, since my seats are not adjustable.
