09-22-2019, 08:35 PM
#21
SSL is not always secure. My last job for 9 years was for an internet protocol testing company. Half of our products were internet security related. VPN is the way to go.
Originally Posted by Larry-NC
That's an unnecessary precaution.
Your connection is https, not http. That means that your computer is encrypting the data with a key known only by the bank's server (and vice-versa). Other people can see that a packet is flowing from your IP address to the bank's IP address because they can read the address headers which have to be clear (unencrypted) to deliver the packet. But they cannot read the data following the headers since that is encrypted.
A VPN prohibits people from even seeing that the packet is flowing from your computer to the bank but most of us don't worry about that.
09-22-2019, 08:53 PM
#22
I believe you meant to write:
VPN is the way to go if you can establish a VPN connection directly to the destination you want to go to.
Ray
2020 Georgetown GT5 34H5
09-22-2019, 09:22 PM
#23
My Solution
Took delivery of a Rockwood this spring with a WiFiRanger 4, yes it will pull in weak WiFi signals but if the connection is slow or overloaded, well it won't over came that. My go to is a JetPack with Verizon under a unlimited plan. Still route it through the Ranger and have family and friends connect to the Ranger since I have both a guest account and family account on the Ranger. When I do find a good external account no reason for each device to re-establish a connection, setup the Ranger once and done.
For a secure connection I have a Ubuntu server at home hosting an OpenVPN server, so each of my or the wife's devices run an OpenVPN app to setup a secure connection back to the house when on a public WiFi even if its running through the Ranger.... thats still a public connection.
09-22-2019, 09:53 PM
#24
What about the King WiFiMax?
When I was at the Rally in Goshen, King was there and their system seemed impressive. Supposedly even though you get connected to a public WiFi the King treats your setup as your own private network with encryption out and back. Most of all the Forest River new units that were on display had King WiFiMax's in them. I am seriously thinking to have one installed with the directional antenna. What are you thoughts on the King WiFiMax?
2018 Cedar Creek 36CK2 (40.5ft)
TST Cap System (Tire Monitoring)
2021 Chevy 3500HD Crew Cab 4X4 DRW Duramax (replaced 2015 Chevy 2500HD Crew Cab 4X4 Duramax)
Curt A25 5th Wheel Hitch (replaced Demco 18K Auto-slide)
09-22-2019, 10:12 PM
#25
If you’re connecting the Ranger to the cellular hotspot how much does the connection slow? My home network will always show 350 to 400 mbps download speeds. When a WiFi Ranger was connected to my WiFi the best it could produce was under 50 mbps. Haven’t looked at the speed difference with the Nighthawk or Jetpack. VPN connections seem to reduce speed by about 25% or so.
I believe that for our purposes (camping, traveling, anything other than real work) speed is not a significant factor. I don’t see any difference in performance when streaming video at 5 mbps vs 55 mbps. It works just fine at the lower speed. The only time I can see the downside of the lower speed is when I connect to a very large database stored on my home based server (Filemaker system). But, once I suffer through the extra 5-6 seconds to get the program started there is no perceptible difference in operational speed as long as my connection is greater than two mbps. The problem is most CG Wi-Fi systems rarely get much over one mbps.
BIRDS AREN’T REAL
09-22-2019, 10:14 PM
#26
How secure are accounts setup with an text or email verification code sent after your password has been entered?
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
09-22-2019, 10:40 PM
#27
I have seen upwards of 55 mbps on the jetpack through the Ranger but speed is directly related to signal strength, stronger the signal the faster the speed. I am also using a MiMo antenna hooked up to the jetpack and it will boost or rather get a stronger signal then a cell phone so it will preform better than a cell phone. As for signal degradation, yes the more hoops you have it will impact signal performance. But for surfing the net its minimal and as for streaming Prime movies I don't see any difference IF I have a strong signal. IE 4G and one bar with everybody else not using the internet. If 2 bars or more don't experience slow down with streaming content.
09-22-2019, 10:55 PM
#28
Ray
Actually its not what I meant. Yes its true that a VPN connection all the way to the destination would be best but I don't wnat to be on a public WiFI with the possibility of packet sniffers recording everything I am sending and recieving. Even if my password is being sent encrypted, I don't want people viewing what I show on my screen. Any banking or email is done through my phone's hotspot which is running VPN.
09-23-2019, 07:23 AM
#29
Little more info, please. You say “banking or email is done through the phone hotspot” but are you really saying you’re using the phone cellular connection. The hotspot is a Wi-Fi setup to allow external devices to use the cellular system. Wouldn’t that open the system up allowing unwanted access to transmitted data via the Wi-Fi signal?
BIRDS AREN’T REAL
09-23-2019, 08:45 AM
#30
Since 99% of campgrounds that have wi-fi have a system that is so weak it's a complete waste of time and money to get "repeater" equipment. You would be a lot better off to go with a cellular hotspot like a Netgear Nighthawk or Jetpack MiFi box. A lot more reliable than public Wi-Fi and a lot more secure, especially if you use it via a VPN.
No need for a router since those hotspots can handle up to 15 connections.
We did the same. We have an Alfa booster and router combo but it does not increase the bandwidth, only provides a good secure connection to a weak system.
We have begun using one of our phones as a Hotspot (unlimited data with our Verizon plan for our phones)
Best solution we have found to date as long as there is Verizoncell service available.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-26-2019, 06:14 PM
#31
Originally Posted by DavidBo
I've been using NordVPN for a bit over a year now and I'm pretty happy with it. I believe you can use up to 6 devices on one account, and they have apps for smartphones. I assume it can be set up on a smart TV, but I've never tried. It will also work with routers that support OpenVPN.
I love it when the antivirus on my laptop sends out little popups trying sell their VPN by telling me "Your location (Provo, Utah) is unprotected!", when I live in Texas. I guess that means it's working!
I also use Nord and you are correct 6 devices. They had a pretty good "sale" on their service recently. Several years for a little over $100.
Have you ever tried using a sever from, say, the Ukraine or Russia?
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
09-26-2019, 07:01 PM
#32
They cannot do that if it's HTTPS. This (and Snowden) is why over the past few years there has been a dramatic uptick in the number of websites running HTTPS. These forums excepted, of course...
The only way your actual screen can be viewed is if you got malicious software (malware) on your PC or you're using some type of remote access or remote viewing software like TeamViewer and it got hijacked (usually from using the same username and password on multiple sites).
Or someone is doing it with binoculars through your windows. No, not a joke. It's called "shoulder surfing".
Ray
Ray
09-26-2019, 07:10 PM
#33
They are far more secure than not using them. But they are now considered weak because too many cellular companies have had their call centers talked into moving someone's cell number to a fraudster. Google Authenticator and similar offline systems are much better.
This is a highly reputable site where you can enter your email addresses and you'll see which breaches they got stolen from. You also can set up alerts if you suddenly show up. https://haveibeenpwned.com/
You also can enter old passwords on this page and see if they were stolen in any breaches. It doesn't mean they were from your account but it does show that many people who think they have a super-secret password actually do not. https://haveibeenpwned.com/Passwords
I used to use the first link in Lunch-n-Learn sessions. The person whose work email address got exposed in the most breaches got a prize.
The picture is for a password of maryhadalittlelamb
Ray
09-26-2019, 08:12 PM
#34
I use the Pepwave SOHO ... it supports wifi as wan. Easily configured. I use my hotspot as the fallback wan source and connect the Pepwave to the park wifi as primary wan source. Works great.
https://www.amazon.com/Peplink-SUS-S...s%2C165&sr=8-1
09-26-2019, 09:12 PM
#35
Router Use In A Campground
Originally Posted by UK Cards Fan
What router do you use in motor home to make it secure? We have a 2015 27' Sunseeker with 3 slides. I'm looking for a repeater for stronger signal and "our" own secure wi-fi within our motor home. When we sign onto the campground unsecure wireless, we notice a lot of secure Netgear. Asus has been recommended to us. It has also been recommended to get a VPN account, Tunnelbear. Any thoughts/suggestions please. Thanks
I am no wiz at internet connection technologies so I am a little puzzled here about how you would employ a secure router in a campground. It sounds as if, in a campground, you can receive the unsecured campground Wi-Fi via your router and make it secure with your router before it reaches your PC. Is that right?
I thought a router had to connect to your Internet provider and I can't understand how you can connect to your Internet provide on a campground away from home. Am I missing something here?
09-26-2019, 10:00 PM
#36
There is no such thing as "secure" campground wifi.
When you use theirs...or McDucks'.....or Walmarts', etc just use it for innocuous stuff,
But for banks, brokerages, or other sensitive stuff, use your cell phone hotspot.
Fussing with VPN's is seldom worth it.
(I don't trust their "trust me" anyhow)
2014 King Ranch Ecoboost Screw, 3.73.....2019 Palamino 27RLSS (customized)
Retired AF Mustang.....Picker always looking to jam.
09-26-2019, 10:20 PM
#37
All these “free” VPN’s are /can be malware just stealing your data. Google/ Android apps were just found many of the VPN apps were actually just collecting your info, some from Russia.
The unsecured WiFi at public places just means there is no password meaning anyone can get on it and scan/try to hack it and other machines. The websites you are going to, if encrypted (https) even a sniffer can’t see the traffic. Maybe avoid your banking websites at a minimum. I highly doubt the camper down the street is scanning computers on the WiFi. Then goes out to roast marshmallows
09-26-2019, 11:17 PM
#38
Retired Old Fart
How many of the old tech guys here remember "wardriving" back in the day?
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
09-27-2019, 12:01 AM
#39
I bought a Winegard Connect 2.0 with 4G for our RV and added it to my Verizon Wireless account. I also just found that Winegards Roadlink C2 has partnered with AT&T to get you unlimited data for $30.00 a month which is by far the best deal out there.
https://www.amazon.com/Winegard-WF2-...sr=1-1-catcorr
09-27-2019, 12:10 AM
#40
