Originally Posted by RvBill3
I removed old deck plate screws and plate. Used new plate to mark enlarged hole making use of as much of the old hole as possible. Used sabre saw to cut compartment bottom to size of larger hole (easy to cut). Cut from bottom up if you don't have clearance for saw inside compartment. Inserted new plate reusing old screws. (I used some sealant around plate bottom and screws.) Total job 15 minutes.
Ditto .....bought 5 inch deck plate at a RV supply place...wonder why they have those
. Took out old plate, made template out of cardboard for new plates outline, traced, took roto -zip about 10 seconds to enlarge hole, put in new plate with 7400 rtv on seal area on plate, drilled in self tapping screws back into plate , covered screw thread that protruded in rtv, viola!!!
Rhino hose we bought or just about anything will fit now!!
