Old 02-28-2013, 05:48 PM   #11
The standard Rhino-Flex sewer hose will fit into the standard rear hose storage bumper. Try it again and rotate the ends of the hoses and you will see that they will fit. It's kind of like this. Why are manhole covers round???? That's the only geometric shape that will not fall into the opening if it were turned around. A square will fit and fall into the open hole. Can you imagine if kids knew manhole covers would fall into the opening????? They would spend all night working on it.
TeJay
TeJay is offline   Reply With Quote
Old 02-28-2013, 05:52 PM   #12
Mountainmanbob's Avatar
these fit into the bumper tube
had one for a while and works nice
plus
nice and long
Blueline Ultimate Sewer Hose™, 25'
[S078-888483]
Manufacturer's Number: 1-0065
$35.99 $35.45
No more clamps, tools, or threading your hoses! Pushover Quick Connectors are installed for a simple, “push-on” connection to other Blueline fittings. Made of superior, heavy-duty vinyl for all-weather durability.
Slunky Sewer Hose Support, 25'L*
Your Price: $56.80
Mountainmanbob is offline   Reply With Quote
Old 03-01-2013, 08:40 PM   #13
Plain Old Member
Paulmlac, should be able to find the larger threaded plug/access hole piece at the boat or marine place as mentioned before. RV dealer may have one. Seen them used for plumbing access in rv showers too. I could have swore I've seen them at Academy before, or maybe something similar. Cut away. Easy fix.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-01-2013, 09:00 PM   #14
Rig is at a storage lot so can't look at it easily. Does anyone know how the base plate is attached to the floor of the storage trunk - does it glue down or get screwed in? Also, is the 4" base plate sufficient or is it smarter to get a 5" so have a little wiggle room? Thanks!
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 03-01-2013, 09:02 PM   #15
SYE
SYE's Avatar
My Rhinoflex hose fits in my rear bumper, you just have to be smart to thw way you put it in there.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 03-02-2013, 05:04 AM   #16
We use a Thetford Smartdrain with our Sunseeker, which has an enclosed tank drain compartment. The hose and fittings have lever lock connections. The hose fits in the bumper and goes through the compartment's floor opening just fine.
The lever lock connections allow you to connect the hose to the dump valve without having to twist the hose. My routine is to connect the dump elbow first, drop it into the dump station, then push the hose into the dump compartment. I flip the levers open and let the hose hang in the opening while removing the dump valve cap and putting the adapter on. The hose just plugs right onto Smartdrain adapter on the dump valve. We've used it for about 250 camping days in two years and it shows no wear. We usually don't stay in any place for more than two or three days, so it has been pulled out of the bumper, dragged across the concrete, and connected a lot of times.
Old 03-02-2013, 06:32 AM   #17
It attaches with screws. I used the same screws for the new one and added some silicone sealant under the lip of it. I used a 5" deck plate and it is plenty big enough.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
