Old 02-28-2013, 10:40 AM   #1
Sewer Hose Questions
Got our unit last August. Through the fall, we used the cheapie sewer hose that the dealer tossed in for free. I would like to upgrade this spring (figure the old one got brittle over winter & I will recreate the scene from RV first trip out).
In reading various forums, it sounds like the Camco Rhino Flex Sewer Kit is popular. Camco 39761 RhinoFLEX RV Sewer Hose Kit - Walmart.com
From reading this forum, I believe the sewer hose is 4 inches wide & it won't fit through the hole which is only 3 inches in the storage trunk. Our unit was made before FR made the hole bigger.
Is the only option to cut a bigger hole? Is it as simple as unscrewing (not even sure if it's screwed in) the old white plate, using a saw to cut a bigger hole, & screwing in a bigger white plate? And, lastly, where can I buy a bigger white plate (I'm not hitting the right string of words to find one on Amazon)?
Thanks!
paulmlac is offline   Reply With Quote
Old 02-28-2013, 11:03 AM   #2
Mountainmanbob's Avatar
that is a good hose for the money
we have two short ones
and
yet another very long 25' different brand
have found that short ones work most of the time
and the long one has been a must at other times
maybe you can cut a 4" hole
then find a cap or plug at Home Depot
or
take your problem to a large RV parts store in your area
we have found ours to carry most everything
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 02-28-2013, 11:06 AM   #3
mjones12's Avatar
I have the Rhino Flex and love it because the ends swivel, making it a lot easier to hook it up straight. But, as you say, it won't fit in the bumper because of those swivel fittings, which don't easily come off. I use a big plastic container with lid to segregate my sewer hose, gray rinsing hose and all other sewer equipment. It doesn't weigh much, and I can just toss it in the bed of my truck. That may not work for you, but I'm sure some other ideas will be presented that will be helpful.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 02-28-2013, 12:14 PM   #4
puff's Avatar
x2
mjones has a good idea. While your at walmart buying the hose walk over to the plastic storage box area and find one that will hold the hose. While your there buy a good pair of long rubber gloves. I place mine inside a zip lock bag and the hose and gloves go into the storage bin. Another good purchase is one of the clear 90' sewer fittings that you can run water backwards to flush if needed. Not that you want to watch what is going down the drain but it helps to see if the water running through your black tank is clean=thus should be empty.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 02-28-2013, 12:28 PM   #5
the best and most expensive by far is the Polychute.
gerrym51 is offline   Reply With Quote
Old 02-28-2013, 12:39 PM   #6
DAISY BOYKIN's Avatar
Rhino flex is the way to go!
Rhino Flex hose I have found to be in my opinion is the best> I have been at camping for around twenty five years. I have used everything that has been avaiable. There are numerous ways to carry the Rhino hose. True it will not fit in the bumper for storage because of the size. Some use plastic boxes from WalMart or other places.
I use a 4" PVC, thin wall irrigation pipe from Lowe's. I use a fitting glued to each end with a 4" screw in plug. I used Stainless clamps to attach the pipe under my RV. You have to remove part of the locking ears on the RHINO hose with a hacksaw for it to fit into the PVC pipe.
Some use the 4 1/2" PVC square fence post cover to attach to the RV.
Enclosed are some photos.
Name:	ROCKY & MODS 001.jpg
ID:	24867   Click image for larger version
Name:	ROCKY & MODS 006.jpg
ID:	24868   Click image for larger version
Name:	ROCKY & MODS 008.jpg
ID:	24869   Click image for larger version
Name:	ROCKY & MODS 009.jpg
ID:	24870   Click image for larger version
Name:	ROCKY & MODS 010.jpg
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 02-28-2013, 02:39 PM   #7
Thanks for the info. Sorry, my question wasn't clear. On the Sunseeker, the dump valves are in a storage compartment. At the bottom of the storage compartment, there is a hole with a screw off cover. The question is about the sewer hose being 4 inches (I believe), the hole at the bottom of the storage compartment being 3 inches (I believe), & what / how to modify to get the sewer hose through the hole.
Old 02-28-2013, 03:03 PM   #8
I've seen this mod ( cutting a larger hole and installing a new hatch) on this site. A search may provide your answer
08 Titan Crew Cab Long Bed with Big Tow
13 Surveyor SV 291
New Holland TC45
Polaris XP550
Berkshireba is offline   Reply With Quote
Old 02-28-2013, 06:14 PM   #9
I have done this mod. It is as easy as you described. What you are looking for is a "deck plate". It is available from boating supply places or Amazon. If you search that term you will find it.
Since the Rhino hose has ends on it, I just coil it up in the sewer compartment.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 02-28-2013, 06:40 PM   #10
Check out member cbvp "built in storage hose issue" post in Modifications and updates. Sorry don't know how to attach a link.
13 Surveyor SV 291
New Holland TC45
Polaris XP550
