Old 06-06-2014, 10:21 PM   #1
Sewer hose storage
2015 sunseeker.docx
greg and I rv.docx
We just bought a Sunseeker 2450. Is there a special compartment for the sewer hose to be stored or do we put it in a serarate container for storage ? We forgot to ask during our walk through.
Thanks.
emmasmimi is offline   Reply With Quote
Old 06-06-2014, 11:24 PM   #2
Average Joe
MrJoe's Avatar
Not really. Some use the rear bumper or make and mount a tube. I just retract and cap my RhinoFLEX hose and store it in the dump valve compartment. Works for us.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 06-07-2014, 12:07 AM   #3
Same here. I bought the new Rhinoflex hoses and they won't fit in the bumper. Just put them in the compartment until I get my new bumper built.
Fozzy is offline   Reply With Quote
Old 06-07-2014, 01:12 AM   #4
Just a member
kandl's Avatar
A Rhinoflex slinky will fit in a std 4-inch RV bumper. It has to oriented just right, but it will fit.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 06-07-2014, 04:29 AM   #5
Witch Doctor's Avatar
x'2, they said they would, well they only got it 1/2 right one end will fit, had to sand of the knobies to get the other side in, gave Amazon a bad review for that one......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-07-2014, 05:12 AM   #6
x2 Fits in sewer compartment. Comes with caps so no problems with residue leaking. Also have the 5 foot (stretched) extension hose, a set of sewer hose supports, and a small plastic box with disposable gloves in the compartment. Also a small bucket I use to hold the end caps, etc., when not in use. Everything I need in one place. Added a 45 degree clear elbow to sewer valve outlet (and leave it permanently attached). Positions right over the deck plate (hole in compartment) so hose doesn't have a tight bend to get out of compartment, and also allows monitoring of dump process.
One of the first mods I did was to replace 4 inch deck plate with 5 inch so hose would fit through it. I think they switched to the larger one at the factory after several of us commented on it here (two years ago).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 06-07-2014, 05:15 AM   #7
We use a Thetford "Smartdrain". It's stouter than the basic hose. I store it in the rear "bumper" and the quick release levers have to be oriented just right to go into the "bumper".
Old 06-07-2014, 09:46 AM   #8
RV Nomad
Rhinoflex will fit without any cutting or sanding. I almost did it myself, then I realized each end will rotate at a swivel joint in order to orient the plastic knobs towards the inside corners of the bumper. Then 90 deg. elbow swivels so that it's end is flat with the inside wall of the bumper. No modifications necessary. You owe Amazon a good review!
xgzx is offline   Reply With Quote
Old 06-07-2014, 10:10 AM   #9
BamaBob's Avatar
A Rhino will fit...barely...sometimes. Just depends on who was making the rear bumper that week
Better solution is to do the fencepost mod a lot of us have done. 5x5" fencepost at Lowes, bolt on the bumper & attach end caps. Use a 4" plastic gutter as a slide out storage/stabilizer. Here is a photo of OC's setup:
OK Lets talk Sewer Mods!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-07-2014, 11:05 AM   #10
PAWDWCamper's Avatar
Our Rhino has fit in our bumpers on past 5ers but the new Sunseeker has a sheet metal screw on both ends of the bumper that stop the hose from going in.
I am afraid to remove the screws since the seem to be holding the metal bumper cover on.
PAWDWCamper is offline   Reply With Quote
storage
