Old 06-03-2012, 07:54 AM   #11
Originally Posted by B47 View Post
Dave - CW sells a kit (Stock #37395) that is an anode rod with a drain plug on the end that, if the picture is correct, allows you to drain the WH without renoving the rod. The package says it is for the Atwood brand WH so I don't if it would work for you.
Dont use the #37395,it is 1/2NPT ,your Surbuban heater is 3/4 NPT. Youroo!!
