Old 05-09-2019, 12:38 PM   #1
Silverado 1500
We are picking up a 2015 Sunseeker 3170DS this weekend. Husband wants to flat tow his Silverado 1500. Anyone tow their truck? Any advice??
lme8200 is offline   Reply With Quote
Old 05-09-2019, 12:48 PM   #2
Is is a 2wd or 4wd? If it's 2wd with an automatic transmission, you can't flat tow it unless you remove the driveshaft.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 05-09-2019, 01:18 PM   #3
4wd
Old 05-09-2019, 01:28 PM   #4
A32Deuce's Avatar
Weight could be a limit depending on the hitch of the RV.
A32Deuce is online now   Reply With Quote
Old 05-09-2019, 02:19 PM   #5
Yes hoping it has the 7500 hitch to match towing ability
Old 05-09-2019, 03:43 PM   #6
Just as confused as you
Scrapper's Avatar
The manual will tell you what you need to do to flat tow the 4wd 1500.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 05-09-2019, 04:11 PM   #7
Your Silverado weighs 6000 lbs, cutting it close to the 7500# tow capacity of that Class C MH.
Might be too much if you plan to tow in the mountains.
What is the GCVWR of the Sunseeker?
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 05-18-2019, 10:38 PM   #8
Sorry late response, I believe 22,000
Old 05-18-2019, 10:41 PM   #9
Max curb weight for a 2017 silverado 1500 is 5500. So hopefully that is enough under for the mountains.
Old 05-18-2019, 11:55 PM   #10
Flat Towing
Hello, I flat tow our 2018 Silverado Crew Cab 4X4 with our class A. I had to add better sway bars, steering stabilizer and a track bar on the rear axle. You probably won't need the track bar, but I would highly recommend the sway bars and steering stabilizer if you RV doesn't have better ones already. I'm guessing you'll feel the tail of the rv being pushed around when towing. Hope this helps
JoePK is offline   Reply With Quote
