Old 05-18-2019, 05:36 PM   #1
SiriusXM antenna location
I installed the SiriusXM receiver in my 2018 Sunseeker 2400W MBS. I currently have the antenna on the dash up by the windshield but the reception is terrible
Has anybody had any luck finding good location for the antenna?
michael.wehrer is online now   Reply With Quote
Old 05-18-2019, 05:52 PM   #2
mudman2's Avatar
I could be wrong but I think it uses a directional antenna. I have one at home and I put it on the roof.
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 05-18-2019, 06:13 PM   #3
We have a REV and installed an Onyx radio in the cab, and placed the antenna inside in the cab-over. The REV has no bunk in the cab-over but instead a pair of cabinets, so we installed the antenna near the roof inside the cabinet. The fiberglass roof doesnít impede the signal and weíve had no problems when facing any direction.
chfwiggins is offline   Reply With Quote
Old 05-18-2019, 08:08 PM   #4
Thanks. I will give that a try.
Old 05-18-2019, 08:28 PM   #5
You bet. Iím happy it worked since we didnít have to drill a hole and donít have a wire going out a door. We just have to keep a clear view of the southern sky when we camp and want music!! When camped we run the AUX cable to the outside speakers and works great.
Old 05-20-2019, 05:17 PM   #6
Hoglou's Avatar
satt radio
Mounted a marine grade (no ground plane) xm antenna on the roof directly above the entry door. Our coach has a cabinet over the door for the satt dish recv and tv connections. Ran the wire down and to the back of the dash.
ID:	205026   Click image for larger version
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 05-21-2019, 07:33 PM   #7
We ran ours out through the slide and located it on top of the roof right behind the driver's side door. Secured it with Eternabond tape and it works perfectly.
dkwalsh is offline   Reply With Quote
antenna, cat, location
