Old 03-16-2015, 07:17 PM   #1
siriusxm help please
Took our first trip in our new 2860ds this weekend. only real problem was the sirus signal through the jenson radio. The signal would cut in and out repeatedly about 10 times per minute. The small box shape antenna is mounted on the dash next to the windshield, but i have read that it has to be on the roof. is this correct? i would presume that on the dash was ok if thats how the camper came. But installation instructions from sirus says it has to be on roof. Any advice, thanks
gasgastwo is offline   Reply With Quote
Old 03-16-2015, 07:21 PM   #2
Boss Hoss's Avatar
Sirus is right.Put it on the roof-they'll catch a good signal and make good radio.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 03-16-2015, 07:31 PM   #3
The roof would be perfect......but you can get away putting it anywhere as long as it has a very clear view of the southern sky. My antenna in my pop up is by the door......if it is facing south...reception is fine. If not, I temporarily place it on the roof.
Trevor43 is offline   Reply With Quote
Old 03-16-2015, 07:34 PM   #4
WrongWayRandall's Avatar
Placing it on the roof gives you a wider view of the sky while sitting on the dash you probably are only catching the very edge of the signal as the roof is blocking much of the sky from the point of view of the antenna. Any obstruction will reduce/interrupt the satellite signal and it takes a brief time to acquire again each time the signal is lost. In our car, with the antenna mounted in a clear location on the roof we lose signal passing under most overpasses...
- R
1975 Westfalia (VW)
2014 Rockwood A122
WrongWayRandall is offline   Reply With Quote
Old 03-16-2015, 07:47 PM   #5
GM
bclemens's Avatar
It is on the roof. The antenna on the dash is for the GPS. Check the roof, make sure it does't have sealant on them like another user here.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 03-16-2015, 08:02 PM   #6
thanks for replys, i must be looking at the wrong one then, i will check the roof tomorrow, other than that had a great time. love the new camper. they have moved on a long way from our previous 2003 model.
Old 03-16-2015, 08:13 PM   #7
thank you, just went and had a look tonight. found about 1/3 of the antenna was covered in silicon. hopefully this was an easy fix.
Old 03-17-2015, 06:36 PM   #8
We subscribe to Sirusxm on our Jensen radio in our 2014 3010DS and never had a problem with reception. Just turn on the radio and listen. Now the GPS is a whole other issue!
chucknviv is offline   Reply With Quote
Old 03-22-2015, 12:33 PM   #9
Puzzlme's Avatar
2013 Sunseeker 3010DS came with Magnadyne and is satellite ready. What do I have and what do I need to have installed so I can get the radio working?
http://rhodaventure.com/
2014 - 15,000 Kilometers (9360 Miles) Alberta through the US to E. coast, up into Atlantic Canada, Newfoundland and back.
2015 - 2 great trips so far. Alberta to Oregon coast, Alberta to Shushwap in BC.
Puzzlme is offline   Reply With Quote
Old 03-23-2015, 09:43 PM   #10
GM
bclemens's Avatar
You need the tuner and antenna which plug into the back of the radio.
Just look on Amazon for the Sirius tuner and antenna...its SXV200 is what we install for the Jensen.
