Old 03-05-2016, 03:12 PM   #1
Size matters....
I had another thread going about connecting a Trimetric battery monitor which kind of touched on this, but I'm still looking for answers here so I thought I would post it as it's own item.
So as in most Class C's I've seen, I have a battery compartment that is pretty much barely big enough to hold two 12v batteries. There's maybe an inch of clearance all the way around, and that's about it.
I also have five connections to my main positive post including the connector to my other battery. Aside from the fact that it looks horrible and probably isn't particularly efficient, this method of connecting is going to make it a difficult chore to get the batteries out when I want to, like in winter. (They're AGM batteries which were expensive).
Some of the replies in the previous post mentioned terminal connectors, but I honestly don't have room inside that box to mount something like that AND have any maneuvering room. I couldn't even mount the shunt for the monitoring system on the side which is why it's sitting on top of the battery.
Try not to laugh, but here's what I've got now. Any suggestions as to what if anything you can think of are appreciated.
2015 Sunseeker 3010DS
jeffreymhardy is offline   Reply With Quote
Old 03-05-2016, 06:43 PM   #2
There are covered terminal blocks that you could mount outside of the compartment.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 03-05-2016, 06:52 PM   #3
That's an idea...if I can find a place close to the battery box that isn't too exposed or too low to the ground
Old 03-05-2016, 07:22 PM   #4
What do you think of this?
Absolute-PD28-Power-Distribution-Output
Old 03-06-2016, 06:57 PM   #5
Hoglou's Avatar
take a look behind the wall where the battery switch is located. I am looking at that same location for an inverter to run the satt box from the battery. I would put the connections in a plasic junction boxes.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-06-2016, 07:25 PM   #6
That's where I have the Trimetric mounted now. And it's probably where I will mount the Solar Charger I'm getting tomorrow. Trying to find some weatherproof boxes for that
Old 03-06-2016, 07:41 PM   #7
Hoglou's Avatar
got a wiring diagram for the trimetric install by chance?
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 03-06-2016, 07:56 PM   #8
Herk7769's Avatar
This is how I installed my Trimetric if it will help anyone.
I uploaded as a PNG file so feel free to modify it as needed for your rig.
Herk
Name:	My wiring diagram.jpg
HAM CALLSIGN - KC3FFW
Old 03-06-2016, 08:03 PM   #9
Hoglou's Avatar
Thank you!!
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 03-06-2016, 08:50 PM   #10
Herk7769's Avatar
Thank you!!
Here are the manuals if you want to read them before you buy.
