Old 06-03-2014, 08:17 PM   #1
Skid Bars
This is on the Sunseeker 3170DS and I just wonder are these skids a standard item on all of the Sunseekers?
Obviously these are intended to drag if anything is going to, I just feel like I would be better off without the skids and just install a skid wheel on the hitch receiver.
I could gain nearly 4 inches of clearance just by not having the skid bars.
I'm afraid I'm going to plow the road in front of the driveway up and the dip is not even very steep, would a wheel on the hitch and no skids be any better?
howzball is offline   Reply With Quote
Old 06-03-2014, 08:19 PM   #2
Average Joe
MrJoe's Avatar
I have them on my 2450.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 06-03-2014, 08:30 PM   #3
I have them on my 2011 3170ds also had them on my 1998 jayco I think they are pretty much standard on a class c
lbrunning is offline   Reply With Quote
Old 06-04-2014, 12:19 AM   #4
My 2013, 3170DS has them. They were tested the first time I tried to pull in my driveway. Super glad they are there. The hitch height on my 3170 is 8" lower than my previous four winds class C.
lowreyfarris is offline   Reply With Quote
Old 06-05-2014, 11:06 AM   #5
I'm glad they are there too, just wished they were a little shorter is all.
If it weren't for the skid bars dragging, I wouldn't have anything dragging.
If you stretch a string from under the rear tire up to the lowest point of the back of your bus, which would be the receiver hitch, you can see that the skid bars protrude down past this line an extra 3" more than they need to.
Old 06-05-2014, 12:06 PM   #6
Twisty's Avatar
"...would a wheel on the hitch and no skids be any better?"
No. The hitch isn't designed for those types of loads and you want the farthest outside corners protected. A centered wheel would promote tipping.
Those bars could be shortened and then wheels could be bolted or welded inside to raise the wheel height.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 06-05-2014, 03:09 PM   #7
GM
bclemens's Avatar
Not so fast. You have to remember that the hitch receiver extends further back. This will be the first thing to hit and is at a greater angle than the main part of the hitch. So if you shorten the skid bars to the point that its 1" below the "line" of the hitch...that receiver will probably hit first.
I watched a guy bury one about 6" into new asphalt. Was not ours...but a 40' diesel pusher towing a suburban. Tried to turn and go up a hill. Had to unhook his toad and gas up the air bags to get moving.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 06-05-2014, 03:16 PM   #8
DAISY BOYKIN's Avatar
Skid bar replacement
I had a 26' Travel trailer with sid bars that would drag almost anywhere. I cut off the bottom "V" part of the skid bars, welded heavy duty caster wheels
to the remaining portion of the skid bars.
Never did drag again, just rolled in and out of places where the skids would drag.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
