Old 03-12-2018, 08:32 PM   #1
Slide control box locations
Where are the slide “brain”boxes on 2014 3010DS located? Also what is the best lube for the slides?
Mike3393 is offline   Reply With Quote
Old 03-12-2018, 08:38 PM   #2
I have a 3050s and mine is under the stove area of the slide. If it isn't on yours then look for removeable panels. Then turn the lights iut so its dark and you'll likely see the glow of the dislay on it.
Chrisc40 is offline   Reply With Quote
Old 03-13-2018, 08:06 AM   #3
Duckogram's Avatar
The control boxes will not be far away because both motors have to plug into it. Follow the wire that comes out of the base of the slide frame on the wall.
As for lubricant, only CRC Power Lube w/PTFE is recommended.
Here is a link to the LCI video on the subject:
https://youtu.be/8KbVRFMo1Rg
ILB ( | )
Old 03-14-2018, 06:25 PM   #4
No-Fish's Avatar
Ive got a 2016 forester 3011, which is the same floor plan as a sunseeker 3010, the bedroom slide controler is under the bed..
No-Fish is offline   Reply With Quote
cat, location, slide
