Old 02-04-2016, 06:34 PM   #11
Your pic looks just like our problem. We go to pick up the rig this weekend. I'll def ask how they fixed it!!
Jubowen is offline   Reply With Quote
Old 02-05-2016, 08:04 AM   #12
rbetzwieser's Avatar
I had the same problem on my 3050s. Even after the factory "fixed" it! I think I finally fixed it. I used a 2 part apoxy behind the flange then added stainless steel screws with very aggressive threads. Kinda like particle board screws. I added 2 screws between each factory screw. If someone at the factory sees this thread you need to add a metal frame behind the flange for your rivet to grab on to. Riveting to the fiberglass does not cut it!
rbetzwieser is offline   Reply With Quote
Old 02-05-2016, 09:17 AM   #13
From what I was told by my dealer ( truth? , I don't know) is that there is suppose to be a metal wall stud right at the opening of the slide box. The mounting screws are suppose to thread into this and sandwich the fiberglass between the tower bracket and the stud. If the screws are pulling out, they missed the stud on the assembly line. Like I said is this true? or just a line from the dealer. Maybe Josh can answer this one.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 02-16-2016, 09:31 PM   #14
Well we have it back. They readjusted the slide and hope that fixes the issue. Was told this is common. Guess we'll have to play the wait and see game. In the mean time we are seriously trying to decide what extended warranty to get. Thanks for all the input here. Helped us to ask better questions.
leak, slide
