Old 09-22-2018, 09:17 AM   #1
Slide out seal issue
Was going to replace a section of my living room seal and discovered the seal appears to be a u channel covering the framed opening. I have not seen or found any seals like this, Am i looking at this wrong? (2014 3010DS)
Mike3393 is offline   Reply With Quote
Old 10-06-2018, 09:09 AM   #2
We have a 2017 3010DS and have a similar issue with the living room slide. Intermittently the top black u channel slides out while driving down the road. We haven't found a good fix for the issue. Let's us know what you come up with.
Jaimberlyn is offline   Reply With Quote
Old 10-09-2018, 10:34 AM   #3
Shredder's Avatar
I have a 2013 3010DS and noticed while retracting the slide it seems the top seal would slide forward. I got up on a ladder and took a look. It seems that they put a small rivet or what looks like a nail head in the trim to stop it from sliding out. I slid the seal back into place and pushed the seal back over the head of the nail. I then used a bit of silicone over the nail and the seal it hasn't moved since.
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 10-09-2018, 09:16 PM   #4
I'm having to replace the seal on our slide of 2012 3100SS sunseeker. if you call Forest River Inc give them the last 8 digits of your VIN number they will tell you the part number for it. You will have to go through an authorized dealer for them to order the part as I understand it FR does not Ship Direct to customer
aemail4sue is offline   Reply With Quote
Old 10-09-2018, 09:21 PM   #5
Mine is a D bulb seal with two wipers one you see on the outside and the other wraps on the inside. It's a two-part item
ID:	188767Click image for larger version
Old 10-10-2018, 11:17 PM   #6
Garrette's Avatar
Amazon has D seals. Check your dimensions and see if they are the same.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 10-13-2018, 10:43 AM   #7
This lady at Lippert was very helpful in obtaining new seals for our Sunseeker.
LUZ CRUZ
Lippert Components
P: 574.537.8900 | F: 574.534.7161
Chas69 is offline   Reply With Quote
seal, slide, slide out
