Old 10-19-2017, 05:21 PM   #1
Slideout not closing
Looking for anyone who can help me with manual retraction of the main cabin Slideout in 3170ds sunseeker. I am getting activity to the slide-at least it's making noise but doesn't sound like the slide is engaging and is stuck out about a foot. I don't know where or how to access the manual system so I can at least get it in so I can drive for service.thanks everybody.
beachbum107 is offline   Reply With Quote
Old 10-19-2017, 05:46 PM   #2
Weekender
Ford1's Avatar
There is another thread on this post entitled 'Schwintek slide motor twisting'. It has a very good explanation of the slide operation, instruction manual and photos. Try searching under Sunseeker for the above title. The thread ran about 6 months ago.
Ford1 is offline   Reply With Quote
Old 10-19-2017, 11:34 PM   #3
Forest river and also Lippert have apps you can download manuals looks very helpful to me
Smcgregor is offline   Reply With Quote
Old 10-20-2017, 03:34 AM   #4
Road Trippin
pismolocal's Avatar
My rear slide in the bed area on my 3011 just decided it didn't want to go in on one side. One side would try to go in the other wouldn't move. A red bar lit up the rear slide control on the control panel. I was able to push mine in from the ouside, Slowly. It would go in about an inch them stop. I then went back in the coach and attempted to extend it slightly then bring it back in till it stopped. Then back outside to push again
Repeated this for about 30 minutes till I finally got it in all the way. Called a local repair place that does warranty work on forest rivers and made an appointment. What a damn hassle. 2017, brand new coach. Owell
pismolocal is offline   Reply With Quote
Old 10-20-2017, 09:16 PM   #5
Garrette's Avatar
First, check under the slide box on the inside for any obstructions. Loose bolts, nuts, etc.
In the compartment next to the generator is a nut in the overhead inside the compartment. I think it is a 5/8". This nut operates the gear box. Use a socket driver to operate the gear box. If it does not move, you could have a broken shear pin in the gear box or a broken roll pin under the couch that connects the left and right gears.
I have experienced a pin shear in the gearbox but, the slide was making a different noise so, I stopped and brought it back in. I have never brought the slide in manually.
Keep us informed.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 10-20-2017, 09:33 PM   #6
Garrette's Avatar
Here are a couple of pictures from the owners manual. Hope they help
The manual is available at swintek' web site.
ID:	154606   Click image for larger version
ID:	154607   Click image for larger version
slide
