09-05-2015, 07:20 AM
#21
The weather stripping worked some what,,, the rubber on the front side of the dinette slide is a mess,,, nothing seams to help that one,,, problem looks to paint on the interior part of the seal ??? I did also find part of the top was not properly rolling over,,, cleaned & wiped it with protectant,,, will check it next time we put slide out,,,
no sure how to ever check the top when camping,,, do not carry a ladder ???
09-05-2015, 07:23 AM
#22
Originally Posted by Boso
I think I am going to try some Velcro using the brush like side as it should last a good while without wearing the slide seal very much and I already have some
Maybe a better option than Grip Tape ???
09-18-2015, 03:17 PM
#23
Just checking in to see if anyone did the grip tape yet? If the weather is nice this weekend I was planning on doing it but was hoping someone would relay positive results first.
2015 Georgetown 351DS
09-18-2015, 03:50 PM
#24
Citrus County, Fl.
I tried a yardstick yesterday and it worked great
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
09-18-2015, 04:41 PM
#25
Slide seal
Didn't try the grip tape but did take three pieces of Velcro about 4" long and space out about 1' on 3' section 3050s finger like side up on Velcro worked perfect only had about 3'-4' that was sticking in the middle of slide
09-19-2015, 08:12 AM
#26
Weather stripping is working very well,,, except for front of dinning room slide,,, As I said that one has some paint on the interior rubber,,, which I believe is not letting it roll over !!! Next time I have the slides out,,, I plan to spray Rubber lube on the painted one ???
09-19-2015, 06:37 PM
#27
Yep.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
09-20-2015, 07:10 AM
#28
Tried both "soft" and "bristle" sides of the Velcro. Neither worked. Decided not to use the step grip tape as I don't like the way the granules fall off and also figured its roughness might wear down the rubber seal. Worried that actual weather strip would tend to get pried loose by the seal hitting it on edge since most weather strip is designed to be compressed/squished rather than have the edge of that seal hitting/digging at it trying to flip over. Sanded the edges of a wood yardstick to make them smooth and rounded and threw it in the storage bay. Quick, cheap and easy. Done, done & done.
10-07-2015, 08:50 AM
#29
Does anyone know who makes the Bedroom & Wardrobe slidouts on a 2013 2500TS ?
10-07-2015, 09:06 AM
#30
Alleged curmudgeon
Pictures of any fix which works would be nice!
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
09-16-2016, 06:48 PM
#31
Slidout Rubbers ???
Resurrecting this thread. I saw a Heartland TT at the campground and there they were. This is what is used to flip the seals. Now, I have searched the Internet, Lowes, Ace to no luck. I am posting the pictures hoping someone has found such an item.
A small strip1/2" to 3/4" wide with a small 1/8" lip about 6 inches long. More eyes looking might net something. Photos were taken with permission.
I think 3 or 4 strips will be necessary in the absence of a window.
Dorothy, Miss Bella and I. Sometimes daughter and grands, loving life.
09-16-2016, 07:04 PM
#32
Attachment 120424
Attachment 120425
Attachment 120426
Don't know why you need that, my seal will flip both ways, what are you putting on the rubber?...
Coachmen M/H
Concord
2018 / 300 DSC
09-16-2016, 07:32 PM
#33
I found this quote.
"All, I contacted Heartland for the slide out seal flippers. The part number is 31107, and is $1.377 a linear foot, + shipping and handling ($9.10 in my case).
It comes with an adhesive strip on the back and cuts easily with kitchen scissors. I applied 1 ft long strips on each side of our 4 slides, about 2" down and 4" back from the outer wall of the slide. Will see if they help, immediately it looks like they will."
https://www.heartlandowners.org/arch...p/t-44566.html
2015 F-250 FX4
09-16-2016, 07:34 PM
#34
Because some of us are not as lucky as you..
Anyway here is a link to an option for this issue...
http://www.forestriverforums.com/for...rs-106404.html
09-17-2016, 12:51 AM
#35
We have the problem every time the slide goes in and out on the drivers side of our 3171. Just found some auto trim that should work from our local PepBoys.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
09-17-2016, 07:48 AM
#36
I use gray self sticking 1/2 x 3/8 foam weather stripping,,, about 3 pieces on each side !!! Works Great !!! White would look better !!!
