Old 11-11-2012, 06:06 PM   #1
Small filter next to water pump
On 2450 there is a small in line filter next to water pump. How often should it be changed and should antifreeze be ran through it when winterizing ?
hankwilliamsjrjr is offline   Reply With Quote
Old 11-11-2012, 06:40 PM   #2
lindy's Avatar
Are you talking about the small about 1-2" dia metal screen basket that's inside a clear container on the on board water tank side of the water pump? If that's it then it's just a metal rinse-able screen meant to keep anything of a size that would damage the water pump from passing thru it from the on board water tank.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 11-12-2012, 11:12 AM   #3
I think thats it. It's the same as the pictured posted in the Water pump thread by RvBill3.
Old 11-12-2012, 12:01 PM   #4
lindy's Avatar
Yes that's just a particle filter to keep sturr from damaging the water pump.
F.R.O.G. member
Old 11-12-2012, 02:40 PM   #5
fonzie's Avatar
You need to run antifreeze through it.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
