Old 02-12-2015, 08:32 AM   #41
KyDan's Avatar
There are many ways to deal with these "parasitic" drain issues.
I am leery of a dedicated switch to power anything like LP or CO detector.
What if you forget to turn it on?
I'm in favor of battery disconnect switch that is at the battery or in the
main battery lead.
It shuts off everything.
Hard to forget it's off and when it's on so are your alarms.
My 2¢
Peace!
Dan & Rita D
Old 02-12-2015, 08:58 AM   #42
Witch Doctor's Avatar
main battery lead.
My 2¢
You make a good point Dan, I use a pre check list so I do not forget to turn on my switches that isolate different things that I found were parastis. Even through I leave my unit plugged in at home I just don't like things that are wired directly to my batteries. This also makes sure that I drop to 13.2 and not boil out my batteries, from the charger reading a load and staying in absorption at 13.6. There is not one unit wired the same from the factory. It took a half day for me to remark everything correctly checking what is tied into my breakers and 12 volt side. Since then I bought the progressive Convertor, which wouldn't read the parasites but with my WFCO it would never drop to 13.2 it was always reading a load staying at 13.6.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-14-2015, 06:07 PM   #43
Timex's Avatar
Originally Posted by gljurczyk View Post
If it's hooked to your refer 12V side I would still add a SPST switch to shut it off when your not using the trailer. All you have to do is cut the red wire and put the switch between 10 min job. It could just be me but I do not like things being put on the same circuit without some kinda of control. Mine was hooked directly to the battery, so no matter if I pulled the disconnect or not it was always hot. Also was that the black one?
The OEM was black and when I ordered, I thought I ordered a brown one but it is more of a milk chocolate color. Oh well, it's kind of behind a small table anyways so nobody will notice(or care). I didn't take a picture(yet) but I will. Down in the back right now, so things like that will have to wait.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 02-16-2015, 08:42 PM   #44
chrismbrock2009's Avatar
I have had a similar issue with my CO alarm in my 3170ds. Over the past year while driving down the interstate the CO alarm went off. This has happened twice. Windows are closed and we are riding at 60mph. I pull over and inspect and find nothing. Odd
chrismbrock2009 is offline   Reply With Quote
Old 02-16-2015, 09:10 PM   #45
caper's Avatar
Do you have a dog in the unit?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-16-2015, 09:31 PM   #46
Nope, no animals.
The one common factor is that both times this has happened I had been on the highway for a few hours. My Sunseeker is used weekly, sometimes daily. So it makes me wonder if its linked somehow to being on the highway for an extended period of time or not.
2014 Sunseeker 3170ds
