Old 04-07-2016, 03:24 PM   #11
mdstudey's Avatar
I will be waiting for you posts. I will be starting off with the Renogy 200 Watt 12 Volt System. While at Big Bend, I saw a fiver with a solar set up. It looked like he had the solar (on ground) to his battery and then he must of had an inverter in the basement as well because there was a 30 or 50 amp power cord running out of the basement to his plug in. What I would like to do is connect the inverter so that I can use any wall socket instead of having to plug in like that guy did. It would be nice for charging things will on the go.
Chuck & Denise + Pata a.k.a the campground Gladys Karvitz
He is a picker, photographer, hiker. She is a quilter.
Both big nature lovers.
2015 23BD Grey Wolf, 2012 Chevy Silverado 1500
2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights
Life is short
mdstudey is offline   Reply With Quote
Old 04-07-2016, 03:33 PM   #12
What is your plan for bringing the #6 down from the roof? I am running a conduit through the wardrobe and down to the drivers side basement compartment. That is where the converter is anyway (and one of my inverters.) I checked with FR and got the location of the roof trusses so I will miss them.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 04-07-2016, 04:12 PM   #13
Hi Scott,
Could you provide FR contact info so I can get roof layout data about my unit?
Thanks.
Rich Phillips
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 04-07-2016, 10:37 PM   #14
RailwayRog
You might want to screw into them when you find out how thick the roof material is.
I started a thread about "installing solar panels on paper thin roof"
2010 Coachmen Prism M240
(2008 Freightliner 3500 chassis)
RailwayRog is offline   Reply With Quote
Old 04-07-2016, 11:41 PM   #15
MH Noob
Tri metric 2030 A is in
So really, this was a pretty easy task. I took alot of care however to plan the routing of signal wires to prepare for the downwire from the combiner box next week. Here is where it mounted up in the cabinets next to the door. I removed the thin panel backer on the inside of the cabinet to reveal a perfect 3 inch cavity to run the wires.
From Inside:
Slimjc is offline   Reply With Quote
Old 04-07-2016, 11:44 PM   #16
MH Noob
She works!!
And Power!
Old 04-07-2016, 11:47 PM   #17
MH Noob
Shunt and such
Here are the photos of the shunt install -
There is a bit of clean up to do, but I figured I would hold off til after the charge controller is hooked in"
Old 04-08-2016, 12:07 AM   #18
Cool! It'll be good to see how you mounted your panels to the roof, and how you routed your wires through the roof to your cabinets.
Here's mine on our Four Winds; I'll be tackling this very task on our new '16 2250 Sunseeker in the next year or two: Solar Panel installation on Motorhome (2010) Photo Gallery by B-N-Mac at pbase.com
way back in 2010, I used a pair of Sharp 80W panels, a Morningstar 45 PWM controller (with remote meter, temp & voltage sensors), 10 gauge wire from each panel to the controller, and 6 gauge wire to the batteries less than 3' feet away. At the time, I spent better than $1200 for the setup. It performed very well for our needs. Today I could put the same setup on for probably $400-500.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 04-08-2016, 01:58 PM   #19
MH Noob
I am using the existing hole cut for the TV Antenna - of course there will be a bit of modification - I will show pics as I am prepping this weekend for panels to arrive Monday.
Old 04-12-2016, 10:44 AM   #20
Also interested in following your progress, so thanks for sharing info and posting your picts. The dealer installed a Samlex 150 panel when we purchased the trailer last year and now I plan to install the TM 2030 RV and the SC-2030 within the next month.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
solar
