Old 04-13-2016, 09:48 PM   #21
MH Noob
Phase 2 - Solar Install
Well after a 6 hour plus time slot - everything is installed and actually working - I will start loading up the photos after I put the little guy to bed.
SO we will begin with the entry into the roof - I went with existing cable entry from the antenna as it lined up directly above the batteries - shortest distance:
Slimjc is offline   Reply With Quote
Old 04-13-2016, 11:40 PM   #22
MH Noob
Feeding the #6 cable straight down through the cabinet and along the wall - found a cable raceway that is almost a match for the wall color:
Old 04-13-2016, 11:42 PM   #23
MH Noob
Took the couch out to find an existing hole to run to the batteries in the step:
Old 04-13-2016, 11:45 PM   #24
MH Noob
Wired up most of the controller, switches etc on the bench - cut a 9inch by 17 inch piece of wood for the backer so that I would have enough clearance when the jackknife was flat - mounted a protective cover to keep things from falling on it and little fingers from touching the hot fins:
Old 04-13-2016, 11:49 PM   #25
MH Noob
And She works:
Rainy day but was still able to tinker with the settings to ensure functionality - excited to test her out over the next week - on our way to Disneyland and North of Santa Barbara - Jalama Beach!
Old 04-13-2016, 11:54 PM   #26
MH Noob
Where to get the info
Ok - so I have been studying for about 9 months on this subject and found two extremely helpful sites. I also read every word, 10 or so times before I started the project ans spent the money. Here is your bible - read all of it:
https://handybobsolar.wordpress.com/...ging-puzzle-2/
Once you have finished there - read everything else in the blog - extremely revealing.I have not personally spoken to Handy Bob - I did not have to - he wrote everything so perfectly, without fluff, it was hard to just not follow his instructions.
90% of my solar supplies were purchased here http://www.amsolarrv.com/
They are great folks and have good prices - not the dirt cheapest but certainly in the ball park. I paid a few dollars more to know the customer support was there.
Another source to cross check info is:
RV Electrical
And of course if you want to know how I put it in - I will answer any questions you might have.
Old 04-14-2016, 12:31 AM   #27
Sagecoachdriver's Avatar
Slimjc, there are a bunch of us over on the Forester Forum trying to work out mounting the panels on the roof. Seems there is an issue with the thinness of the fiberglass and plywood and whether is is strong enough to hold the panels securely. How exactly did you mount them? We are over at this topic-http://www.forestriverforums.com/for...in-105452.html
Have a nice trip down here to SoCal. Been to Jalama many times and Disneyland too! Safe Trip!
SCD
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 04-14-2016, 07:35 AM   #28
Slimjc...nice installation. Would you say that the roof backer plywood is maybe 1/4 or 3/8 PT plywood. Looks like it but hard to tell from the photo. Should be plenty of holding power with some coarse self tapping screws. Nice photos.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-14-2016, 08:35 AM   #29
MH Noob
It is 1/8 fiberglass, 1/4 substrate, 1 inch of styro material. Sandwiched very tight - go here for your mounts: AM Solar: Support — AM Solar
Old 04-17-2016, 03:39 PM   #30
MH Noob
Quick update, drove from salt lake city to Los Angeles in high winds, solar panels stayed put. Vhb tape, screws and dicor......
Old 05-02-2016, 08:04 AM   #31
BFRTECH, here's the diagram. Everything goes to one side of the shunt, except one little wire. I just got mine done last week, with a battery box from Harbor Freight. I'm loving it so far. Only reason to plug in is for A/C.
81 TriMetric 2030 and SC-2030 Wiring Layout
mnoland30 is offline   Reply With Quote
Old 09-06-2016, 10:58 PM   #32
First, thank you for sharing your experience! Very valuable!! We have a Sunseeker 2690 (wiring area somehow similar to yours!) and I believe we have same interior colors.
How's the solar system treating you? In a regular sunny day how many amps is it able to put in the batteries? Do you manage to keep them fully charged?
As for the conduit for the visible wires, did you get it online?
thx!
bambam is offline   Reply With Quote
Old 09-06-2016, 11:25 PM   #33
MH Noob
thx!
It is treating me rather well! I rarely need to run the genny when dry camping, usually just for the Micro. Adding a 3rd panel for cloudy days!
The conduit I grabbed from a NAPA auto store - seemed to work perfectly.
Old 09-07-2016, 08:35 AM   #34
Slimjc, were you able to hide the cables from under the cabinet to panel?. How many panels and watts?
Old 09-07-2016, 09:10 AM   #35
MH Noob
Yes, I will snap a photo later today when I have a chance. I used a cable management system and cut it to fit - it has a sticky back to one of the pieces. I used mineral spirits to clean up the "sticking" area. I feared it might pull off the wall paper - but after 9 months there is no sign of the paper coming from the wall. I was about to use wall screws to secure it - but the stick em worked very well.
solar
