Old 12-05-2016, 12:42 PM   #1
Solar panel system on my Sunseeker 2300
I made a short video showing the nuts and bolts of my solar installation.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 12-06-2016, 12:18 AM   #2
Great over view. Thanks!!
Toytec is offline   Reply With Quote
Old 12-08-2016, 09:06 PM   #3
Nicely done. Thanks for sharing.
dbareford is offline   Reply With Quote
Old 12-09-2016, 06:48 PM   #4
Nice job Snowman! After viewing, I ordered an inline fuse from Renogy for each of my four panels. Initially, I placed one fuse after the combiner. Your assessment concerning a short in a panel makes sense and fusing each panel gives some peace of mind.
2015 Sunseeker 2300 Chevy
swuebbels is offline   Reply With Quote
Old 12-09-2016, 07:04 PM   #5
The inline fuses are a great solution. I was not aware of them at the time I decided to make up that box.
Old 12-10-2016, 10:58 AM   #6
I felt the same way - there needed to be fuses at the source.
On my Sharp panels that I put on the 2000 Four Winds in 2010, no wiring was included. I installed inline fuse holders within the connection box, then used waterproof electrical connectors through the roof for the wires.
As I used 10 gauge wire from each panel to a combiner box, I used 15A ATC fuses.
Solar Panel installation on Motorhome (2010) Photo Gallery by B-N-Mac at pbase.com
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 12-12-2016, 03:00 AM   #7
Be careful which inline fuse you use. Some of the fuses themselves fit too loosely in their fuse holders which results in an intermittent connection.
I had this frustrating problem when I installed my solar system last season. You should not be able to feel and hear your fuse when you shake the completely fuse assembly.
To fix this problem, I wrapped some electrical tape around the fuse to increase its diameter and then I put a spring in the fuse container so the fuse has no slop along its longer axis.
Skyliner is offline   Reply With Quote
solar, solar panel, sunseeker
