Originally Posted by Snowman9000
The inline fuses are a great solution. I was not aware of them at the time I decided to make up that box.
Be careful which inline fuse you use. Some of the fuses themselves fit too loosely in their fuse holders which results in an intermittent connection.
I had this frustrating problem when I installed my solar system last season. You should not be able to feel and hear your fuse when you shake the completely fuse assembly.
To fix this problem, I wrapped some electrical tape around the fuse to increase its diameter and then I put a spring in the fuse container so the fuse has no slop along its longer axis.
