Originally Posted by GerryW
It would make sense to me that trusses would be spaced to support AC and other vents. Would they be immediately below the wood backer panel or would there be insulation between the truss and the wood? Would they be on standard spacing? I could drill holes to experiment but I would rather not. This type of info should be more available with the decrease in price of solar panels. Travis has requested info from Engineering but of course I gotta go since I have all the parts :} I wish there was another way to get the power cable in other than thru the fridge roof cap. Thanks
Since Travis said there were no trusses on this model I drilled 3/8 holes and used 8 toggle bolts per panel. Under the 2'' wide angle i used a silicone formulated to stick to aluminum, fibreglass, fingers, hair, blankets etc. I put enough silicone to seal the holes and hold the panels forever. I put the controller by the entry door to minimize wire length and aggravation. Right now my batteries are fully charged and ready to go. I realize it would be difficult for FR to to offer mounting strips or locations given the variance in panel sizes, but still.... Anyway a little guidance would be appreciated from FR.
