Old 04-26-2019, 09:31 AM   #1
Senior Gold Member
rthomaslyons's Avatar
Solar Ready
Many trailers and motorhomes come with a receptacle marked Zamp solar ready, it is also marked Warning Use Only with Zamp products. In the interest of universality why would a RV manufacturer make something that many people might want to use, so proprietary? What if Zamp isnít around in two years...
rthomaslyons
2019 Sunseeker 3010 DSF
rthomaslyons is offline   Reply With Quote
Old 04-26-2019, 12:09 PM   #2
Following
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 04-26-2019, 12:25 PM   #3
I am using a 120 watt go power solar kit that is compatible. Had it for 2 years and it works fine.
Marnenorden is offline   Reply With Quote
Old 04-26-2019, 01:35 PM   #4
Senior Gold Member
Zamp compatible
Mine will be 160 watt and a controller output of no more than 10 amp so I wonder what the Zamp is rated for
rthomaslyons
Old 04-26-2019, 03:47 PM   #5
Solar Ready
I found this online.
Old 04-26-2019, 04:11 PM   #6
Lacey's Spring, AL
formerFR's Avatar
that's just a deal between the manufacturer and the solar company to 'brand' the RV models with a type of 'proprietary' connection to a solar panel - which is the 'brand' solar panel THEY want you to HAVE to purchase!
BUNK...
by any solar panel you want, and run it directly to the battery bank - you don't need any 'special' solar connection - it's just a sales tool for the solar company.
formerFR is online now   Reply With Quote
Old 04-26-2019, 04:43 PM   #7
Flybob's Avatar
This is mostly a marketing ploy. Solar ready is simply a connector on the RV and a wire to the battery compartment. The wire is not heavy enough to handle a serious solar install. Best bet is Ignore it and start from scratch.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
solar
