Agree with Dutch, check your tires and understand howmuch stuff you can carry. As for the Magadyne unit, forget the GPS and Bluetooth. Just buy a Garmin 760/770 RV unit. It has Bluetooth built in and works well. If you really want it to work, turn on the unit and in the lower left corner is a reset button. Use something small. Press and hold until the screen goes black. It will reset the unit back to factory. Give it a try.
And now something you did not ask about.
How to use sound surround system with TV
Turn on Tv and Magnadyne Dash unit. On the dash unit pick Home in upper right corner.
Use arrow in lower right to go to next screen
Pick AV2.
TV should be playing through house speakers and cab speakers.
Turn off cab speakers by rotating switch located at key hooks to B position.
To turn off TV speakers. Use the TV menu, go to Audio and choose TV Speakers and choose off, if desired.
The TV remote will control volume level however, max volume is set in the dash unit as well as the equalizer settings.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
