Old 05-07-2013, 12:13 PM   #1
Hoglou's Avatar
somebody stop him!
Ok I know, back to back posts. But like in Dirty Harry "I got to know". When you plug in park cable on the right rear of the coach, where or which wire is it in the over the door cabinet? As I did not get the outside ent center I want to push the direct tv signal form the King Dome out the little hole for tailgating tv.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 05-07-2013, 12:18 PM   #2
KyDan's Avatar
I would be helpful it you'd use subject line that is appropriate to your post....
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
KyDan is online now   Reply With Quote
Old 05-07-2013, 02:57 PM   #3
The outside cable connect usually goes to the antenna amplifier. When the amp is on, it sends signal from antenna to tv. When amp is off, it allows the cable signal to pass to tv. Therefore the cable is attached to the back of the antenna amp. Remove cover plate that contains the amp and it will be on the back side.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 05-07-2013, 03:31 PM   #4
bob213's Avatar
Here's a picture of the back of your antenna hookup.
http://www.winegard.com/kbase/upload/2451489.pdf
bob213 is online now   Reply With Quote
Old 05-07-2013, 04:27 PM   #5
Hoglou's Avatar
thanks guys... my little wheels are turning in my head.....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
