Old 09-26-2015, 09:09 AM   #1
Hoglou's Avatar
Speaker switch
DW informed me that the speaker switch does change the output location. Honestly I never saw a need to move it. So what should the settings control be before I tear into it?
Hoglou westGA
KM4HQQ 146.640mhz
Old 09-26-2015, 09:13 AM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Little more info would help. Type of radio and camper and what your wanting to do. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 09-26-2015, 11:41 AM   #3
Hoglou's Avatar
switch
On the 2300 sunseeker with 5.1 you should be able to switch speakers (I guess from cab only, coach only, or both. We do not seem to have that function. The question is what should be A and what should be B?
Hoglou westGA
KM4HQQ 146.640mhz
Old 09-26-2015, 12:11 PM   #4
On my previous tt, A was front speakers only, B was rear speakers only, and C was both front and rear. Did you pull the switch and check for loose wires?
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 09-26-2015, 02:43 PM   #5
On my 2300, "A" setting is front cab speakers and rear ceiling speakers. "B" setting is front and rear ceiling speakers. "Both" is just what it says.
Ceiling speakers are better sound (obviously) than cab speakers, so when I am listening to music or DVD at campsite "B" is best. When traveling down the road, it is hard to hear the navigation if you have front ceiling speakers on, so "A" works better.
My DW is getting good at jumping up and changing back to "A" as we leave a campsite, because I always forget to do it when packing up.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 10-02-2015, 08:11 PM   #6
Love My Sunseeker
DXSMac's Avatar
I have that, and it doesn't seem to affect anything. I think it is meant for when you have outdoor speakers, I don't. (Sunseeker 3180)
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 10-03-2015, 10:39 AM   #7
From what I was told it is non functional if you have surround sound. I do have SS and switch does nothing.
markangie24 is offline   Reply With Quote
Old 10-03-2015, 10:48 AM   #8
We have surround sound and the switch does work. "A" is cab only, "B" Coach only and Both is both. We had an issue with the coach speakers and it turned out it was bad connections because of two improperly installed wire nuts.
Use the audio controls (balance, front and rear) on your system to isolate the speakers and check for sound. If you can't isolate them it's a probably a bad ground on one or more of them. Because of the way it is wired it certainly could make the switch useless.
Bob and Joy
2013 Sunseeker 3010DS
rhumbert is offline   Reply With Quote
Old 10-03-2015, 11:44 AM   #9
On 3100SS...no outdoor speakers...A is cab speakers and rear surround, B is front ceiling speakers and rear surround, and Both is all speakers.
Going down the road I leave on A and change balance all the way to the front...that way I hear the nav and my music without bothering anyone else.
Watching a movie is on B with balance centered.
At a concert tailgating is on Both, centered balance with windows open and volume up!
rad_jr is offline   Reply With Quote
Old 10-03-2015, 07:43 PM   #10
Ours is a 2013 2450s and never has worked. Everything is controlled from the radio.
