Forest River Forums
Sunline User Photos
Old 02-01-2012, 07:56 AM   #11
Forest River Class C's
It should be, unless they ordered it in a specific way.
Old 02-01-2012, 08:15 PM   #12
Thanks for the info.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 02-02-2012, 07:05 PM   #13
Radio power
I believe the dash radio in my 2012 3120 built in November operates on the chassis battery since it requires the ignition key to be on for the radio to function.
ATVer is offline   Reply With Quote
Old 02-02-2012, 07:43 PM   #14
Probable. It has been a running change as we tested out new radios. So there may be some 2012's that are still run off the chassis, but most everything running now is wired off the coach batteries.
Old 02-02-2012, 08:42 PM   #15
Sirius question
Thanks. Another question. Does the radio come with the Sirius mode? The Radio has the Sirius emblem and it appears to have a satellite antenna integrated into the roof TV antenna but Sirius doesn't come up with the Mode button. The radio is a Jensen JRV210.
Old 02-03-2012, 07:57 AM   #16
No, It is "Sirius Ready" which simply means that the head unit can control a Sirius receiver. I wish the radio mfg's would come up with a better term. You still need to have a tuner and antenna for the Sirius section to work. The software is built in so that you can control that tuner from the native display on the JRV210.
Old 02-05-2012, 11:33 AM   #17
electrical and plumbing schematics
Does anyone know where one can get plumbing and electrical schematics? Two things I'm trying to determine on the 3120 is if plugging in the coach also keeps the chassis battery charged and is the water filter in the flow path when hooked up to city water? From following things inside and under the unit I believe both answers are no.
Old 02-06-2012, 08:08 AM   #18
From what I understand, there is a charge line running to the chassis battery so that it will charge when plugged in. In addition there is an "emergency start switch" so that if you were to deplete the chassis battery, you can push the button while turning the key, using the house batteries to start the engine.
The water filter is a "whole house" filter. (all water). I know that some people have taken the filter out of the system if they are on city water and the pressure is not high enough.
Old 02-06-2012, 12:32 PM   #19
Thank you. I subsequently obtained the electrical schematics my 3120 and the charging line you mentioned is shown. I also have the drain piping schematics and my dealer is working on getting the water supply schematics. Then hopefully I won't be bothering you with anymore questions.
Old 02-07-2012, 07:37 AM   #20
Insider
ATVer...if you have a Jensen dash stereo, yours is powered from the chassis batteries.
jamiller45 is offline   Reply With Quote
» Online Users: 592
103 members and 489 guests
0721SSROO, 09grizzly1, 2007Rockwood2601, 4tonns, austincpr, Badie, bean, Bearcat55, Bigjimt, bignugget, BlakeB, bob34787, Bob_Loblaw, bouldercamper, brandon0214, brookside, Buster1281, Cafjackracing, caper, Cascade Bob, CHD Dad, chevy02, chof16, cyclepuck, darkcloud, dasimser, deerslayer, DGrissom, dimurrrw, djorgensen3, DonG, donn, dsdaniels, dunnnc, Emptypockets, Flying dutchman, Ga.Lineman, Great Horned Owl, HAARubicon, HemiCab, Hob, HockeyDad217, Iggy, Jack67, jaxfl, jdefeo1, JDWeir, Jeep4Two, JeffK, jes520, kamp k, ldmcmahan, LeadPoop, LFugate, lindy, lisalynn48, micalo, mike1329, milw156, mlhalter, mn_guy, mrdon003, mtnguy, Pa-cj5, papap, ParrotHead, Patrick29, pg_rider, pixleys, PrairieBoy, punkaccountant, rdwin, rgmiller32, ROCKIN 34, ronhanson, Rugged Brown, RV Guy, RV Van, SabreSam, sail2liv, schrederman, sellis1053, Skippkon, snowbrid, Stank Bait, Steve7575, stevem4134, superk1035, tedstr, Tee, terryh, TheFlagGang5, TheSasks, toclark491, tonybab, travyp, Triguy, Twinbluelake, vp22er, VTX Al, Waterfowlwarrior, wolfpack21643, woodsman
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
