Old 12-25-2015, 08:32 AM   #1
SS 3170DS Air Bag Questions
We have a 3170DS, which I understand has air bag adjustable shocks in the rear. How do you tell how much they are inflated and based on that measurement, what is the recommended pressure level to start out with? We'll be pulling a toad, does this play into a different level of pressure? Thanks for the education, it's appreciated.
Linda
LTRVing is offline   Reply With Quote
Old 12-25-2015, 08:39 AM   #2
Citrus County, Fl.
GL1800Rider's Avatar
You are going to get a lot of replies on this... I have had good luck running 70# in my 3011. Toad does not seem to put any additional weight on the rear. A lot will depend on how much weight you are carrying past the axle. Most will lose a couple of pounds every week so they should be checked often.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 12-25-2015, 01:30 PM   #3
grumpy0374's Avatar
I keep our Lexi at 70 psi, but you can experment to see what gives you the best ride.
You need to get a good tire pressure gauge that will read over 100 psi.
Most bags are rated up to 100 psi. When filling using a compressor, be very careful and add air only a "blip" at a time. The bags are actually small, and it only takes a few seconds to completely fill a bag. 2-3 seconds can add quite a bit of air, so "blip" once or twice and recheck pressure, and add as needed to bring pressure up.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 12-25-2015, 02:41 PM   #4
Hoglou's Avatar
X2 on 70. Consider checking the lines for rub points. I had a leak in year one. Bought replacement line and fittings, and is now completly covered by flex (split rib) tubing....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 12-25-2015, 06:20 PM   #5
RETIRED
n-e-d's Avatar
X2 70# Worked really well for me. Greatly improved handling. You should have been shown the two Schrader fill valves in compartments behind rear wheels. A good electronic tire gauge makes checking pressures easier.
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 12-25-2015, 11:49 PM   #6
Thanks, I was shown the valves but never told the psi recommendations or procedure to adjust the bags.
Linda
Old 12-26-2015, 11:06 AM   #7
tmhyer's Avatar
Fyi they are not air shocks. They are air bags
tmhyer is offline   Reply With Quote
Old 12-26-2015, 11:26 AM   #8
Boso's Avatar
Hoglou mine were covered with that from the factory and half covered with spray foam mine still leaked
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 12-26-2015, 02:58 PM   #9
Hey Hoglou where did you get line and fittings? I want to reroute the lines to be in one compartment and also not use the push in fittings
.tmid_modified { background: #E4F1FD !important; border: 1px solid #3385D6 !important; } .tmid_modifying { background: #E4F1FD !important; } .tmid_popoutblock { display: table; position: absolute; top: 1px; left: 1px; visibility: hidden; width: 120px; height: 40px; background-color: #FFFFFF; z-index: 9999; color: #666666; font-size: 16px; box-shadow: 0px 5px 10px rgba(0, 0, 0, 0.25); text-shadow: 1px 0px 0px rgba(170, 170, 170, 1); }.tmid_formFillHint { display: table-cell; vertical-align: middle; font-size: 16px; }.tmid_icon { width: 24px; height: 24px; }.tmid_popoutblockicon { display: table-cell; vertical-align: middle; width: 24px; height: 24px; padding: 8px 8px 8px 8px; }
Mark1 is offline   Reply With Quote
Old 12-27-2015, 06:29 AM   #10
rsscully's Avatar
Tip when filling the bags, set the regulator on your compressor to the desired psi. When the air stops flowing into the bags the pressure will be exactly where you want it. No "blipping" required. Lol
rsscully is offline   Reply With Quote
