Old 06-17-2015, 11:49 AM   #1
knockando's Avatar
Stabilization Scissor Jacks
I have two scissor jacks bolted to the rear chassis a few feet behind the tires. They are a huge pain in the ***** to operate as I have to crawl under the rig to get the drill on the hex bolt. I can't be the only one that has to do this and can't be the only one that thinks it sucks. Any ideas out there for stabilization, operating these existing jacks? I'm not interested in an auto/powered system right now.
Thanks RV peeps.
knockando is offline   Reply With Quote
Old 06-17-2015, 11:55 AM   #2
Weld a pipe extension on the socket with a shaft in the end OR just buy a long extension and cut the ratchet end off of it.
Old 06-17-2015, 11:57 AM   #3
knockando's Avatar
Holy crap, I was *JUST* looking into that. Found this 4 ft Extension for Soil Augers, Carbon Steel
So if you get it mounted correctly you can just bend over a little hook the drill up to the shaft that is sticking out under the rear bumper and buzz them up and down?
Old 06-17-2015, 12:11 PM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
yes, that should work, but do you need a 4foot extension? sounds a little long to me.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-17-2015, 02:33 PM   #5
knockando's Avatar
I'm going to measure tonight but I suspect you're correct. I probably should weld but might try stainless brackets.
Old 06-19-2015, 08:23 PM   #6
rbetzwieser's Avatar
Thanks RV peeps.
You mentioned that you had 2 scissor jacks. You may already know this but you probably have one behind the front bumper as well. I didn't realize it until I did my first oil change! If you think the rear jacks are hard to access wait until you try this one.
rbetzwieser is offline   Reply With Quote
Old 06-19-2015, 09:05 PM   #7
osgood's Avatar
Do they do much good? Curious?
osgood is offline   Reply With Quote
Old 06-19-2015, 09:27 PM   #8
Ford Idaho's Avatar
Are they bolted on?
If so what would happen if you turned them 1/4 turn so the hex bolt faces the side?
Old 06-20-2015, 06:40 AM   #9
Yes they help a little bit. I was actually thinking about buying the big foot (hydraulic) setup until I went to my dealer and asked them to give me a demo on them with a class c they had in stock. It was not that much better than the scissor jacks as far as sway and movement goes.
Old 07-06-2015, 04:02 PM   #10
knockando's Avatar
I think they do, wife said they don't. I've never been in a RV with Bigfoot so not sure what to expect. My father in law had a TT with 4 scissor jacks on each corner and every time someone got in and out I thought I was going to roll out of bed. TT's would benefit from a 'stair saver' a lot more than an RV would, IMO.
Old 07-06-2015, 04:03 PM   #11
knockando's Avatar
Second that, I asked my dealer about it and he said not to waste my money on a bigfoot system. The benefits of the stabilization are not even close to what you pay for them.
Old 07-06-2015, 06:26 PM   #12
Wait till next year...
n-e-d's Avatar
You may just want the proper sized extension for sockets and a drill adapter so it will serve more uses. I have Bigfoot and wouldnt have any other beats stabilizers hands down
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
n-e-d is offline   Reply With Quote
Old 07-06-2015, 07:15 PM   #13
Scissor Jacks
I have a 2015 2300 Chevy. Does it have scissor jacks?
Ed Traweek
Indianola, MS
2015 Sunseeker 2300 Chevy
Ed Traweek is offline   Reply With Quote
Old 07-06-2015, 07:19 PM   #14
Ford Idaho's Avatar
It might have one.
Old 07-07-2015, 07:55 AM   #15
knockando's Avatar
Don't get me wrong, if I was getting a new unit I'd almost require that it have them. But I think it's hard to justify spending $3500 for Bigfoot on a used rig.
Old 07-09-2015, 09:16 PM   #16
2012 2300 does not have scissor jacks, but I have never felt the need for them. Very little movement (2 adults), except when getting in or out of bed.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 07-19-2015, 05:41 PM   #17
I added Bigfoot a month after purchasing 2014 2860. I drove to the manufacturer in michigan. Cost was just under 4000. I agree you still get sway but is something I wouldn't live without. Park, press 1 button and ready to go
Pacostaco is offline   Reply With Quote
jacks
