Old 02-25-2019, 08:49 PM   #1
Hoglou's Avatar
start relay for 6.0 chevy
I'm posting this in the C Section for those chevy 6.0 folks like me instead of the electrical forum. I had a starting failure that was repaired while I was on the road as a relay in the fuse panel. Quick and easy all is well. So I get home and look at the relay (like 5 same number relays in the box for varied apps), mine all had the number of 13502750.
Great, easy enough I thought I will pick up a spare and leave it in the coach. So went to the local big box counter and was told it looks alot a like some we have but the numbers are different.
Given the doubt of those pesky little details of the relay guts I went home to look it up myself..
Here is what I THINK I know, the 2750 above replaced by
15328867, replaced by
19115082, replaced by
191156058, replaced by
D1780C which is also known as a10071A1.
If you know otherwise please chime in before I buy a spare (10$)....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 02-25-2019, 09:37 PM   #2
Usually Confused Member
emm-dee's Avatar
I hate it when suppliers/mfgr keep changing part numbers. Kubota is the worst of all. I've seen them change part numbers three times within six months...and then change it back to the original number.
An Amazon search returns that relay with several different numbers, including the -6058 you listed. Lotsa results for D1780C.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 02-26-2019, 11:50 AM   #3
Head Rambler
That's just a standard 5-pin automotive relay SPDT configuration with 12 vdc coil voltage. Pretty much anything you buy that will plug in will work.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 03-04-2019, 11:43 AM   #4
Hoglou's Avatar
The number is "AR172". Finaaaly...
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
