Old 01-05-2019, 11:50 AM   #1
Frankie Z's Avatar
Start RV from house batteries
I have a 2018 3010DS my former RV 2650S had a switch where I could start my RV from house batteries if needed. I cannot find the switch in the 3010. Is this feature an option? I thought it was standard. Any info on this would be helpful.
Frankie Z is offline   Reply With Quote
Old 01-05-2019, 12:34 PM   #2
Lacey's Spring, AL
formerFR's Avatar
the switch may be labeled AUX or BATTERY BOOST or similar, or may not even have a label at all...
also, look in your battery or inverter bay - see if you have a 12v D.C. coil by Trombetta, or WhiteRodgers, etc.... which may indicate you have one... or it could even be in your engine bay, mounted on the sidewall.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
99,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is online now   Reply With Quote
Old 01-05-2019, 01:13 PM   #3
The battery connection switch is located on the left side of the driver's seat base (when sitting in the seat). However, if you have power seats the switch is located on the driver's seat but on the front of the seat base between your legs.
Dr Safety is offline   Reply With Quote
Old 01-05-2019, 01:18 PM   #4
Frankie Z's Avatar
Thanks to all who replied. I will follow the advice next time I go to storage lot. These are all suggestions that need to be checked out.
Old 01-06-2019, 08:13 PM   #5
Delco Bobby's Avatar
That is correct.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 01-07-2019, 11:15 AM   #6
Wolverine 1945's Avatar
2013 2500TS, switch is on the left side of drivers seat !!!
Wolverine 1945 is offline   Reply With Quote
batteries
