Old 06-14-2019, 02:59 PM   #1
Step adhesive
The glue on my second step rubber pad has basically liquefied. now the pad slips with every step. The old glue is a honey like consistency but does not hold and the old OEM screws just pull through the rubber
suggestions?
Moose61 is offline   Reply With Quote
Old 06-15-2019, 10:19 AM   #2
Garrette's Avatar
Step adhesive
The glue is really a silicon adhesive. Mine got really tacky nasty, so with some patience and mineral spirits , cleaned it all up and used the 3M auto trim double sided tape to hold everything in place. Did not take a lot of tape. Worked for me.
The inserts for house entry mats, the inserts, one can change, are almost a perfect fit to sit on top of the rubber treads to wipe feet on.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 06-21-2019, 04:18 PM   #3
I just re did mine. Use turpentine to clean everything first. The used contact cement to glue it down. Just be careful with contact cement. You have one chance to get it positioned correctly.
johnlantz is offline   Reply With Quote
Old 06-21-2019, 05:26 PM   #4
SailorSam20500's Avatar
I attached some trimmed carpet squares to my rig. $3.00 at Menards. Got two steps from each square. Attached them with the adhesive used for basement vinyl tile flooring which was left over from reinstalling some loose tiles at my mothers house before it was sold. Been on for about 2 years now and still holding well.
Easy to work with, paint it on position the material, slide around if necessary, then just leave it alone for a few hours to dry.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
