Old 05-25-2015, 08:53 AM   #1
Cool stove top cover and mysterious polls in Sunseeker
After getting home with our new Sunseeker 2450 we discovered that the glass cover for the stove would not fold out of the way in order to use the stove. The problem was that they installed the hinges backwards. I changed the hinges after staightening them out from all the wrong bending and they work fine. Not very good quality control. I also found two 2.5ft polls with rubber tips on each end. Does anyone know what they are used for?
fishrball is offline   Reply With Quote
Old 05-25-2015, 09:08 AM   #2
The poles are probably for a slide out while traveling.
Old 05-25-2015, 10:48 AM   #3
Thumbs down Mystery Polls
I thought of that as a possibility but can't figure out where to put them and slide should be in while traveling. They are still a mystery to me.
Old 05-25-2015, 12:20 PM   #4
Wandering's Avatar
I have the sister model, 2451s. We pondered the poles for awhile too! The are to lock the slide in place by wedging up top inside. Don't think they are needed unless you were to have a slide problem.
Great floor plan ain't it.
Forester 2451s
Wandering is offline   Reply With Quote
Old 05-26-2015, 08:02 AM   #5
Floor plan
The floor plan is the reason we bought this model. Thanks for your advise. I will see if I can figure out where they wedge. I guess it is to keep the slide from going out while driving?
Old 05-26-2015, 09:44 AM   #6
Class C Representative
Joshua Cavitt's Avatar
In case you have to manually control your slide you can put them in between the slide and wall so your slide doesn't slide out while driving.
Joshua Cavitt is offline   Reply With Quote
Old 05-26-2015, 10:31 AM   #7
JimOneil43's Avatar
Joshua, wouldn't it be a good idea to put some of these things like this in the Forest River owner's manual, so it's not such a mystery to a new buyer? I have seen so many questions on this forum about things that I would have thought would be a normal thing to explain in an owner's manual.
Just wondering ??
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 05-26-2015, 10:45 AM   #8
Each new unit should be getting instructions as well as a picture to show how to use the slide locks. I'll check and make sure they are getting sent out.
Old 05-26-2015, 12:29 PM   #9
widogmom's Avatar
I was wondering about the poles myself...thanks for the heads-up, everybody, and to fishrball for asking good questions. I thought the weird stove top on my new Sunseeker was just different from my old RV, because it folds exactly like the cover to DH's iPad...perhaps more intuitive for the computer generation?
2015 Sunseeker 3010DS
2005 Honda Element (toad)
Now, Voyager, sail thou forth, to seek and find.
widogmom is offline   Reply With Quote
Old 05-26-2015, 01:08 PM   #10
RETIRED
n-e-d's Avatar
Guy who did my PDI told us to put them away and forget about them unless we had a slide problem. Seems people put them up on the slide and forget about them ,then wonder why slide is not going out as they continue to push button. Have seen some suggestions if you do use them put a ribbon or strap to remind you there up there
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is offline   Reply With Quote
cover, sunseeker
