Old 12-24-2015, 08:24 PM   #1
Stove top exhaust flapper
I'm having problems opening the stove top exhaust flapper door. Don't want to break them. Do the opening tabs slide down or flip out? Thanks for your response. Merry Christmas!!!
CJ Forever is offline   Reply With Quote
Old 12-24-2015, 08:26 PM   #2
nomad297's Avatar
Push up.
Bruce
nomad297 is online now   Reply With Quote
Old 12-24-2015, 09:04 PM   #3
Boso's Avatar
Or pull down those little tabs keep it from opening going down the road take a broom handle or something and push up easiest way
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 12-24-2015, 09:26 PM   #4
papap's Avatar
They are a pain. You have to push really hard.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 12-24-2015, 09:48 PM   #5
You have to try to push up and sort of "out" at the same time. PITA most times.
2011 Traverse LT, 3.6L, FWD
Old 12-24-2015, 10:50 PM   #6
I'm given up for the night. Will try again in the morning. Thanks for the assistance. It shouldn't that this hard to open a vent door. The two little swivel arms on the older doors were much easier.
2016 Sunseeker 3010DSF
Old 12-24-2015, 11:54 PM   #7
A32Deuce's Avatar
Once you get it open you will realize they are not that hard. Just up and out a little harder than you think.
A32Deuce is offline   Reply With Quote
Old 12-25-2015, 12:41 AM   #8
Kilday4's Avatar
Use caution. I broke one of the tabs. I just leave it open all the time now. It took 2 technicians during the walk through to get it open.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 12-25-2015, 05:14 AM   #9
The swiveling tabs on the Heng's vent flap of our 2011 Sunseeker were easy to use, but the flap itself was a piece of junk. The plastic hinge pins were too small and broke easily. Forget to latch it and the pins would break off when you drove.
I had one break due to gusty wind even with the latches in place. After the third breakage I replaced the plastic pins with a piece of stainless steel rod. Some replaced them with small hinges.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 12-25-2015, 08:03 AM   #10
Georgia Rally Coordinator
aceinspp's Avatar
Old tt had one was not to bad to open. Ha new tt does not have one. Go figure. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 38
aceinspp is online now   Reply With Quote
