06-14-2015, 10:22 AM
Stripped Screws in Panel
This is above my refridgerator. The bracket on the left stripped and came off. It was putting pressure on the right bracket due to the hydraulic arm so I just took down the whole thing.
What's the best way to repair this? Can I fill the holes with something and just reattach?
06-14-2015, 10:24 AM
06-14-2015, 10:38 AM
Why not just put in 4 new screws (2 per side of course) that are a slightly larger diameter and be done with it? If you're concerned about them pulling out at a later date, simply put a small dap of glue on the threads before screwing them into the "wood".
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
06-14-2015, 10:49 AM
You can fill the holes with some wood glue and small slivers of wood or tooth picks, Let it set up and reinstall the screws. Do not use a self tappping screw when going into wood. They are not made for wood, only metal.
06-14-2015, 10:57 AM
Cyber Phrenologist
For added strength, drill a 3rd hole in the hinge and go back with 3 screws.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
06-14-2015, 11:07 AM
Use wooden golf tees (not plastic) place in hole with glue and lightly tap on them with hammer. Allow to dry then cut them off flush and re-drill holes. Problem solved.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
06-14-2015, 11:32 AM
Squirt wood glue in the holes and shove 3 or 4 toothpicks in each hole, break them off and install the door immediately. Don't wait until the glue dries, by installing immediately, the 4 screws will be somewhat locked in place.
06-14-2015, 11:44 AM
Yep. X2. Is is a great way to fix stripped holes in wood. Works great.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
06-14-2015, 12:39 PM
Wait till next year...
Tend to go with OC's method. Quick ,easy, use wood slivers or matchsticks if no wood toothpics and the glue will set screw and fillers
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
06-14-2015, 01:26 PM
Yes use OC 's method but first squirt some water in the damaged holes and soak the tooth picks then stick them in the Gorilla Glue before sticking them the hole and breaking them off or cut them off with a knife. Gorilla glue bonds to metal and will bond to the screws. the water soaks in to the wood and the gorilla glue seeks out moisture that will make it penetrate the wood in the frame work better. Wood workers trick when restoring any screws that has been striped out.
06-14-2015, 02:32 PM
Might drill through and use machine screws and nuts/washers. Would be much stronger
06-14-2015, 02:39 PM
JB Weld the stuff cures hard.
Fill the hole, let JB cure, drill and screw.
06-14-2015, 02:44 PM
Toothpicks and glue. My vote.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
06-14-2015, 03:30 PM
Yep works every time!!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
06-14-2015, 03:53 PM
One of the better ways I've discovered is drill the holes clean the same size, fill with epoxy putty and re-drill a pilot hole the proper size for the screw. Failure to use a pilot hole contributes heavily to weakness of the connection.
06-14-2015, 06:24 PM
Prefer the toothpick method in wood and mollies in drywall.
06-21-2015, 10:17 PM
I would drill and glue in dowels. Cut off, sand smooth. Pre drill and insert screws.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
