Old 09-16-2019, 12:23 PM   #1
Stuck in Ohio with open slide
Help. I am in ohio with my dinette slide open and not closing. Got the front loose by removing pin in drive. Cannot get back gear loose to push in. HELP
TSman
2014 Sunseeker 2500 TS Chevy
TSman is offline   Reply With Quote
Old 09-16-2019, 12:24 PM   #2
PicsClick image for larger version
ID:	215133Click image for larger version
TSman
Old 09-16-2019, 01:17 PM   #3
Until you get a response here from another owner... Call and try to get through to this fellow.
Jim Feece
(574) 206-7609
jfeece@forestriverinc.com
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,100 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,680 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
Larry0071 is offline   Reply With Quote
Old 09-16-2019, 01:18 PM   #4
Ally Operations Analyst
Bobstoy2's Avatar
I was in DC once and could not get my slide to go in, after all the panic found out the engine had to be off for the slide to work. Not sure if that helps but it was surely a lesson for me. Good luck with resolving the issue.
Bobstoy2 is offline   Reply With Quote
Old 09-16-2019, 02:36 PM   #5
Did you try the manual crank in the gear box located next to the motor? I think it is a 5/8" hex hanging down below the motor.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
Old 09-16-2019, 02:59 PM   #6
Engine is off. I could hear motor in slide working and see manual crank turning. Seems like a gear problem. Trying to just push slide back in. Front is free but the back is stuck. Spoke to FR and they said take motor off which I did but it is still stuck.
TSman
Old 09-16-2019, 03:01 PM   #7
Made call and left messages.
TSman
Old 09-16-2019, 03:07 PM   #8
2012 Solera
From experience with our 2012 Solera - as mentioned above, look for a hex on the back of the slide motor. Turning that should drive the slide through the gearbox.
If that fails, on mine there is a square drive coming out of both sides of the motor/gearbox unit - one side to the forward gearing the slide; the other to the back gear. I believe I see that drive tube in your second picture. A bolt and nut through the square drive tube at each end connects the drive pinion gear to the motor driven gearbox. Removing a bolt each on both the front and the rear drive tubes should allow you manually push the slide in.
Hope this helps - Jim
Your messages came while I was typing. Sounds like removing the bolts on the square drive tubes is necessary.
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-16-2019, 03:29 PM   #9
Jim
I removed a drive bolt on the right side and that is loose. Can't find one for the back or left side where the motor is. Everything is shielded and tight in there.
TSman
Old 09-16-2019, 03:57 PM   #10
Just want to be sure we are talking about the same "manual override". Mine is located in the outdoor storage compartment below the motor, it is the 5/8" hex in the photo sticking through the black plastic cover.
Old 09-16-2019, 06:35 PM   #11
Manual override does not work. The motor will spin it. Apparently the gears in the box above it are shot. I took the motor off and the back side with the gearbox does not move. Cannot figure out how to remove the right angle gear box.
TSman
Old 09-16-2019, 06:39 PM   #12
Anyone know how to remove this. I can't even take screws off to tdd try to split it. Click image for larger version
TSman
Old 09-16-2019, 07:12 PM   #13
RV Nomad
I know that part all too well. I just replaced the same parts on my 2013 2500 ts last month. It's called the ragbox, made by Venture industries. I couldn't buy just that part, have to buy whole assembly with motor and gearbox. I replaced it myself in my driveway. Only way to do it is to remove slideout room from the coach. The bolts holding the ragbox in place are in the black square tubing. There is also a long drive shaft on the other side that must be slid out after loosening a gear that is set screwed to it. No way to access bolts, the gear, or the shaft without removing the room from coach. I will start another post with Pics showing my adventure. IMO, I think the ragbox design is garbage, mine failed after 100 to 150 cycles. Had to also wait 3 weeks for part, they were back ordered. What does that tell you? Have someone hold in the button while you push from the outside. I was able to get mine in that way.
2013 Sunseeker 2500 TSF
xgzx is offline   Reply With Quote
Old 09-16-2019, 09:42 PM   #14
Thanks for the reply. Unfortunately my slide will not go back in. Had all day to figure out what you posted. Plan tomorrow to remove bolts holding track to slide and then hammering track to see if it will go in. I had taken motor off already.
TSman
Old 09-16-2019, 11:22 PM   #15
2012 Solera
Desperation move - maybe a pipe wrench on the shaft that is sticking out that would normally drive the other end of the slide?
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-17-2019, 03:02 PM   #16
I had a similar problem last year. The pin in the gearbox was broken. If you dismounted the motor, you probably see that the end of the shaft has a slot at the end. This slot is used to drive the transmission axle using the pin. If the pin is broken, the motor turns but not the gearbox. If I remember well, you will have to open the gearbox and replace the pin. There are some small bolts to remove (I don't remember how many, 2, 3 or 4) to be able to open the gearbox. We had another post on that subject in the past, maybe you can find it. There may be more details in it.
Hope I am clear, excuse my English, my primary language is french.
RFLLambert.
2014 Lexington 265DFS.
RFLLambert is offline   Reply With Quote
Old 09-17-2019, 03:07 PM   #17
On the gearbox picture you posted on #12, we can see two bolts (maybe I should say screws). I am not sure but maybe there is another one behind the shaft.
RFLLambert.
Old 09-17-2019, 03:38 PM   #18
Where are you in Ohio? If in the Akron-Canton area, there is a first class RV repair shop in Alliance (15miles east of Canton) 330-823-6776.By far the best shop I have found in my 15 years on the road. If you use them, please tell that Kirk recommended them ( I used to live there years before we started RVing )
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 09-17-2019, 03:51 PM   #19
I'll be interested to see how you removed the room as a DIY project. Every time I run the slide out I worry that it won't come back in!
grafic is offline   Reply With Quote
Old 09-17-2019, 03:57 PM   #20
I have the same slide mechanism, here are a couple thoughts.
In this photo you can see the two bolts holding the gearbox to the frame, I don't know how you would get them out except by cutting a hole in the slide floor. If you could get them out the gearbox and shaft would move to the side enough that the gear would clear the rack.
Also, on mine, looking under the slide at the rack and the gear on the gearbox shaft I see two setscrews. On mine one is visible and could be loosened with a 12 inch extension and hex bit, if the slide moves just a bit the gear would rotate and the other setscrew would be accessible. Then the rack and the slide should be free from the jammed gearbox.
ohio, slide
