Old 07-01-2016, 01:36 PM   #1
Stuck with one jack down 3010DS HELP
Just pulled into camp ground and one Big foot jack went down only.
Now it want go back up nor will the other 3 jacks do anything?
Any ideas thanks
kitejunky1 is offline   Reply With Quote
Old 07-01-2016, 01:42 PM   #2
Ford Idaho's Avatar
Fuse first, did it trip/blow?
Rig in park, Emergency brake on/off?
Neutral or park?
Old 07-01-2016, 01:49 PM   #3
lgray's Avatar
Any ideas thanks
After ruling out breaker...
Is the system hydraulic? if so, fluid?
lgray is offline   Reply With Quote
Old 07-01-2016, 01:57 PM   #4
LittlePM's Avatar
Not sure what kind of rig you have, it is a motor home check the fuze by the house batteries
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 07-01-2016, 02:09 PM   #5
None of the breakers were tripped I'm definitely in park with the parking brake on.
Right rear keeps flashing on the control box however left rear is the one that is stuck down it also pushed into the Sand by 2 inches.
How can I manually release the pressure
Old 07-01-2016, 02:20 PM   #6
Ford Idaho's Avatar
You rig may have shifted some and put the ram in a bind.
I would dig under it to see if it releases.
Old 07-01-2016, 02:20 PM   #7
lgray's Avatar
Help link:
Bigfoot Leveling System Troubleshooting & Tech Support
Old 07-01-2016, 03:32 PM   #8
chideock's Avatar
You probably did. Try the emergency retract, if you have that control button.
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 07-01-2016, 03:33 PM   #9
i dug it out and got it up THANKS. i batteys are bad. what size are they ? i dont see any markings on the ones i have
Old 07-01-2016, 03:37 PM   #10
Ford Idaho's Avatar
Great!
If you can post a picture, someone here may be able to ID them for you.
ID tag may be molded on the side.
