Old 02-21-2015, 07:53 PM   #1
Sub-woofer not working 3100 SS
Watched a dvd tonight and realized the sub- woofer is not working. Checked all viewable wiring and fuses. Anyone else have something like this happen? I suspect it has never worked. Sub is under the couch. Thanks for any info. In advance. Is there any special settings needed on the Head Unit?
ActionJackson is offline   Reply With Quote
Old 02-21-2015, 08:09 PM   #2
dan-nickie's Avatar
I know our rigs are not any way alike except it is FR
I found a small switch in the entertainment cabinet that turned on the sub.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 02-21-2015, 08:19 PM   #3
We had a similar problem with ours. Turned out to be excess cable; screwed up the whole TV component system. Go figure.
SkipnTerri is offline   Reply With Quote
Old 02-21-2015, 09:28 PM   #4
GM
bclemens's Avatar
Try with the radio and not the DVD (turn bass way up). see if it is working then.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 02-21-2015, 10:15 PM   #5
Sure enough ! Went to the EQ mode on the H-U and cranked the bass to max and the woofer started thumping. You're the man.. Thanks.
Old 02-21-2015, 10:19 PM   #6
GM
bclemens's Avatar
Don't get too excited yet. It means it's wired to the wrong blue wire.
There are two blue wires on the Harness. One is power antenna and one is amp power.
Yours is wired to power antenna so sub only works when radio is on and the power antenna would be needed.
Old 02-21-2015, 10:27 PM   #7
So you are referring to the main H-U harness? What needs to be done to get the sub to work for DVD's?
Old 02-21-2015, 10:43 PM   #8
GM
bclemens's Avatar
Pull the head unit and connect it to the "other" blue wire.
Old 02-21-2015, 11:33 PM   #9
The other blue wire has a white stripe on it.
Remove the engine cowl cover and remove the dash panel.
You should be able to get at the wires from there.
I was able to fix mine without removing the head unit.
jst3 is offline   Reply With Quote
Old 02-22-2015, 07:28 AM   #10
Ok. Will do. Thanks !
Thanks for the info. Appreciate it,
