Old 05-18-2016, 03:07 PM   #11
KyDan's Avatar
The final check requires you to remove the burner tube again and test for
voltage across the heating element connections.
If you have voltage there and no heat it's the element again.
IF you don't have voltage at the element you have to check up stream which
is the rocker switch, or thermostat/safety switch, or power at the outlet??
You really need to check for power at the outlet somehow.
My 2˘
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-18-2016, 03:57 PM   #12
My 2˘
Good luck!
And, be sure the tank is full before turning the heater element on. my 2 Lincolns. Now you have 4.
EdnKat is offline   Reply With Quote
Old 05-18-2016, 09:59 PM   #13
If you have the rocker switch for the water heater in the on position at the convenience center your water heater will only work on propane.
Gear Grinder is offline   Reply With Quote
Old 05-21-2016, 12:44 PM   #14
Try looking for a rocker switch outside on water heater that need to be on the On position, but make sure you turn it Off when you're not plug in shore power
goots is offline   Reply With Quote
Old 05-21-2016, 12:50 PM   #15
raspivey's Avatar
You can run them both at the same time.
Old 05-21-2016, 02:40 PM   #16
Yes, but you will be using propane and also using shore power, no need for that
Old 05-21-2016, 03:20 PM   #17
raspivey's Avatar
Useful when first heating up and when taking showers to replenish faster. I do that and then turn off the propane.
Old 05-21-2016, 03:36 PM   #18
Doesn't sound correct to me. My (and most) Suburbans will run both gas and electric at the same time.
2011 Traverse LT, 3.6L, FWD
heater, hot water, suburban, water, water heater
